Changing Global carrier implements. How to get it to a 'neutral/non-bearing' position
   / Changing Global carrier implements. How to get it to a 'neutral/non-bearing' position #11
I've sometimes found it easier to crowd/dump it over forward, not so much that it will fall off when it lets go, but enough that the attachment is reasonably balanced. Some of those the attachments don't have the brackets in the exact right place and that can make the locking rod bind.
If the locking rod has grease points, lube the snot out of them at any opportunity. If no grease points, I've found spray chain lube to be effective. Or the rod can have a tweak. Don't worry I've had plenty of hammers bars etc out!!
   / Changing Global carrier implements. How to get it to a 'neutral/non-bearing' position #12
Minute I read you were having trouble I thought you were setting it down to release.
Yes leave it in the air "level" then release the latch. You can still set the attachment down where ever you want, then pick up the next one while still in the seat.
2018 KENWORTH T800 (A58214)
2018 KENWORTH T800...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
NEW Woods 6ft Finish Mower (A55315)
NEW Woods 6ft...
2018 Caterpillar 287D Compact Track Loader Skid Steer (A56857)
2018 Caterpillar...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
