changed hyd fluid
/ changed hyd fluid #1
sam5570
south west virginia
new holland tn70
well i changed all my fluids in my tn70 today and i had what i concider alot of metal on the magnet on the rear drain on hyd fluid. i hpoe i don't have some kind a problem. has anyone else had this? been about 5 years sence changed.
/ changed hyd fluid #2
"A lot of metal" as in filings or chunks? Filings are normal over that length of time and the magnet is doing its job keeping them out of the hydraulic system. I am assuming that you logged 1,000 to 2,000 hours over this period.
/ changed hyd fluid
it was just small stuff real small. 400 hrs on the tractor and 90% of that hard hrs bush hogging.
/ changed hyd fluid #4
The filings are probably coming from normal wear of the work you are doing plus from the initial break-in of the gears. Magnetic plugs are used for this reason.
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
