Changed fluids, filters
/ Changed fluids, filters #1
wnenkow
JD 5045D
I had my mechanic out to do a complete tune up. Hydraulic drained and replaced same with oil. All filters replaced. He just drove it back and forth a bit and checked the fork lift and back lift worked. I was ill so did not get on until today several months later. Tractor will not drive forward or back. Could their be air in the line? If maybe which one and how do i fix?
/ Changed fluids, filters #2
That's a mechanical transmission with a dry clutch, so it's not a fluid issue. I would say he put some of the levers in Neutral that you don't usually do and now won't move. Have you checked all the levers to see if it's in gear?
There is the range lever + reverse on the left side and the main gears (1st to 4th) on the right side of the seat. I imagine one of these is in Neutral.
First thank you for answering
I know at this point both are in neitral. The right hand gear was in first, when i first started i put left in first and no movement. How should I have gears?
How should the gears be arramged?
/ Changed fluids, filters #5
You choose the direction you want to go (forward or reverse) with the left lever. Then with the right lever, you choose what gear you want from 1st to 4th.
The left lever also choose either high or low range for forward only.
Both levers have to be in gear for the tractor to move.
Thank you ill give it ago tomorrow. Really appreciate it
Ill give it a try tomorrow. Thank you.
/ Changed fluids, filters #8
I had a little experience like this, buying a backhoe from an old farmer... he mentioned he was having problems with a tractor, not moving... I don't remember exactly but he had (or some kids) moved one of the levers into neutral. I think it was High/Low - I asked about it and he said, that he never touched that one!!!
Once he engaged it, everything was fine... he was planning to have the dealer come out to pick it up!!!
I agree. There is one lever that i never touch. So i think thats why im confused.
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
2015 Case TR320 (A64126)
2015 Case TR320...
2023 Bobcat Mini Grapple (A64126)
2023 Bobcat Mini...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
