change out battery in a 418
   / change out battery in a 418 #1
Trackks9
green bay, wi.
pt 418/ IHI mini excavator
Has anyone changed a battery on a 418, It look's like to me that the
pump assembly and exhaust system have to be removed,
   / change out battery in a 418 #2
I have done it on the 422 and had to remove the exhaust system. Not the pump. I did realize that I might have to slide the motor assembly over by loosening the bolts that hold it to the tractor and pry it a little bit. As it turned out, mine barely squeezed out. I bought new exhaust gasket, but did not use them. You can call Power Trac if needed of course.
The pump assembly is not too hard to remove. I did it when I repalced the ignition coils.
Not enough wiggle room between frame and pump, sliding the engine over
is my next step, I believe the only differance between our machine's are
engine HP and a oil cooler
   / change out battery in a 418 #4
I'll have to remove my muffler on the Kohler to get the battery out on my 2001 PT425. I still have the original battery in it. This may be the year. :eek:
Moss, pick a warmer time of year,It's cold up here, I have 454 hr's on the
machine, It's still the original battery, other then routine mantanence, not
one repair issuse,
   / change out battery in a 418 #6
At least that's one advantage the red PT's have. The battery is on top. Easier to disconnect when there's a fire. lol !
   / change out battery in a 418 #7
Put some PT Blaster on the muffler bolts the day before and 30 minutes before loosening them. It works wonders. It does what Liquid Wrench claims to do.
   / change out battery in a 418 #8
:D:D:D:D:D:D:D
The newer model 400 series have the battery up high, too. I like the model year that PJ has. Everything seems to be in the right spot.
   / change out battery in a 418 #9
MossRoad said:
:D:D:D:D:D:D:D
It also looks like a normal battery instead of the kinda odd shape that the earlier ones are. Maybe I could put one on the bumper or in the weight box. Actually mine was pretty easy to remove and the muffler came off easy with PB Blaster.
Battery is changed, ended up only having to remove the exhaust system,
It will go easier the next time around, what year's did they build the red
one's?
   / change out battery in a 418 #11
MR, what year is that, the one you like? When did thay stop putting Kohler engines in the 400 series?
   / change out battery in a 418 #12
Mine is a 2001 model year. I think PJ's is a year newer than mine. They have had several changes in the 425 model since then. Plastic gas tank like mine. Metal tank built into the hood. Relocated oil filter. Higher lift height. Longer wheelbase. Stronger wheel motors. Lots of changes. Most for the better.
When I bought mine, they were using Kohlers in the 425 and different engines in the 422 and 418. Not sure what year they stopped using the Kohler and went all Robin.
   / change out battery in a 418 #13
I'm surprised the exhaust had to be removed. On my 422 I moved the fuel tank out of the way, removed one of the fuel tank brackets and the heat shield. It was a tight fit but I was able to pull the battery up and out...whole process took about 15 minutes. The original battery only made it through 2 winters. Fortunately thay are fairly cheap to purchase.
   / change out battery in a 418 #14
Thanks for the info MR. The reason I asked was I am looking at a used one & the owner doesn't know when it was built. However I have written it off.
Thanks
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
