Change oil before winter even though hours are low?
   / Change oil before winter even though hours are low? #21
break in oil really doesn't matter anymore, we get what comes from factory in new engines. going back the OP question, imho yes, 20 hrs on a new zero turn engine would warrant a change regardless even what the owners manual recommends. oil change intervals have been extended for enviro concerns, not the longevity of engines, etc in those manuals.... so make that 1st change now. & document for warranty.
yes to what has been suggested, use full syn engine oil,. & don't forget the initial hyd oil/filter change schedule, (go full syn for that as well) for engine oil, i use Rotella T6 on mowers & tractor. best regards
   / Change oil before winter even though hours are low? #22
I'm surprised it doesn't specify break-in oil change at 5 hrs.
   / Change oil before winter even though hours are low? #23
correct. maybe in a forced oil filter system, it may be longer, but agree, i'd err to low hrs for 1st break in change on a smaller engine...back to the original question, change now
   / Change oil before winter even though hours are low? #24
Hmm, I been schooled on oil today. I had no idea break-in oil was old school stuff.
Thats why i come here
   / Change oil before winter even though hours are low? #25
I am not sure what engine you have, but Kawasaki recommends the oil and filter be changed at 5 hours.
   / Change oil before winter even though hours are low? #26
I have My ZD326 serviced every February for oil, new blades, filters, leveling, etc. Then replace blades, change oil, and minor adjustments as needed. Usually start mowing in march and go into November. usually 6 acres at a whack, sometimes more. I don't like letting oil set through winter. It can get moisture in it.
   / Change oil before winter even though hours are low? #27
I have a zero turn that I purchased in July. It has only 20 hours on it. The manual says to change the oil every 50 hours. It seems on this forum many people change the oil before winter. Not sure if that is wasteful without only 20 hours. Could it wait until next summer when it clocks 50 hours?
Look on your oil container and note if it has an expiration date on it. If not then go by hours. If you go by time periods then you could have a year that it was only ran 1 hour. Would you still change oil after one year time period? (When you purchased it new do you think oil was added on date of purchase or date of manufacturing or date of delivery to dealer?) Setting around and only being used occasionally causes more harm than the time period oil is in a motor. Oil never wears out, it just gets contaminated. That's the reason you see some oils advertised as "environmental friendly" containing up to 50% reprocess oil. Use a quality oil with a (HD) filter to match extended run time. Mobile 1 synthetic works excellent for me in zero turn and New Holland Workmaster 50.
   / Change oil before winter even though hours are low? #28
As a previous post said “oil is cheap, machines are not”. I change my oil in the winter when I put my mower to bed. I don’t want dirty oil sitting in the crankcase all winter no matter the amount of hours. Sludge and dirt will just settle in the engine over the winter.
That's should have been filtered out by your filter.
   / Change oil before winter even though hours are low? #29
Oil is cheap, repairs aren't. With a new engine I would change the oil now. The best of manufacturing leaves some near microscopic imperfections that get cleared up in the first few hours of running. Just about all are caught by the filter, some may not be. I may be old school, but I change the oil on a new engine in the first ten hours and after that at the recommended interval
   / Change oil before winter even though hours are low? #30
I think if you want to change it at 20 or 50 either one. But after winter.
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
UNUSED FUTURE FT380R STAND ON SKID STEER (A57192)
UNUSED FUTURE...
2007 Ford F750 (A55973)
2007 Ford F750...
PALLET OF ALUMINUM PARTS (A57192)
PALLET OF ALUMINUM...
Prime 452 (A53317)
Prime 452 (A53317)
