Chipper Champion Wood chippers
/ Champion Wood chippers #1
Poacher Hater
Any opinions on Champion wood chippers for my pto? Pro vs Cons, etc.. Thanks
/ Champion Wood chippers #3
I did a ton of research on chippers and ended up with the Wallenstein. PTO power and it feeds itself without the hydro feeder. Tough as nails, direct drive (no belts!) and throws the chips a long way.
Check 'em out: BX Wood Chippers - Wallenstein
I had the manual Champion and did not like it. Traded up and got the hydro one and it is pretty good, but very expensive. I had a clogging issue until I flipped the blades to the new sharp side and it is much improved since. I just can't see how the cheap China chippers can compare.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2018 Lodal EVO MAG-20 20yd Side Loader Garbage Truck (A66736)
2018 Lodal EVO...
WACKER NEUSON LTN6L LIGHT PLANT/ GENERATOR (A65056)
WACKER NEUSON...
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
PORTA POTTY (A67714)
100 GALLON FUEL TANK (A68842)
100 GALLON FUEL...
