chainsaw sharpener- would this work ?
   / chainsaw sharpener- would this work ? #1
Renze
Elite Member
the Steernbos (Holland)
Zetor 3011, Zetor 5718
I was thinking about the chainsaw sharpener i've seen at the local smith and the workshop of a national infrstructure company where i worked a few months..
It looks very simple, just a grinding disk mounted under a specific angle, on a pivoting plate that grinds the chain. Would it be do able to make one myself using an old chainsaw bar as holder, to be clamped in the workbench claw, with a plate attached to it that has a hinge with another plate to where a small angle disk grinder is mounted ?
I think that's basically all it is. Or do i overlook something ?
Has anyone done something like this before ? and how well did it work ?
   / chainsaw sharpener- would this work ? #2
Unless you really want to build your own....you might want to log on to www.HarborFreightusa.com and order the item on the left:
I have a similar one from HarborFreight and it does a pretty good job. Right now, the price is as good as it gets.
OkieG
   / chainsaw sharpener- would this work ? #3
A really good chain saw sharpener has an indexer that precisely positions the teeth so that all the teeth are ground to the same length. It also has a fixture for precisely grinding the guides. I think that if you take a close look at a "production" grade stationary sharpener like most of the Stihl shops have, you may not be satisfied with something of the caliber found at Harbor Freight.
   / chainsaw sharpener- would this work ? #4
I have had really good luck with a Dremel Tool and the $10 chainsaw sharpening attachment. Most of us already have a Dremel laying around, and if you don't then here is your chance! /forums/images/graemlins/smile.gif
   / chainsaw sharpener- would this work ? #5
CT_TREE_GUY - I'd be really interested to hear your ideas on chainsaw sharpening. What do you use or do with your dull chains? This is not a challenge but a respectful question. You probably use a chainsaw more than any of us combined. If you sharpen your own - I'm sure you do, what equipment do you use. I have an older Silvey that does the job for me and quite well. Madsen still stocks anything I need to keep it running. Clyde
   / chainsaw sharpener- would this work ? #6
CT_Tree_Guy had a whole series of posts on how to sharpen chains saws awhile back. Search for them.
   / chainsaw sharpener- would this work ? #7
I actually use a dremel too. I buy the stones from the Stihl shop.
OkieG, thanks a lot but what will be the mail and handling costs to send it to me in the Netherlands ?? /forums/images/graemlins/ooo.gif
The picture and remarks from the other guys give me a clear idea of what to keep in mind if i do build a jig.
   / chainsaw sharpener- would this work ? #9
Harbor freight is "Out of Stock" on the sharpener. I know because I tried to order one 2 weeks ago when they had them advertised for $39.99. I ordered an identical one from Cummins Industrial instead for $39.99 and it got to my door step in about 3 days. I've sharpened 4 chains so far and for my needs, I am extremely pleased. I figure I can break even on the cost with about 8 sharpenings. Anything more is gravy.
Regards,
Duber
   / chainsaw sharpener- would this work ? #10
Here's what I use, fromNorthern Tool - about $20. I like the fact that when I'm out where there isn't any electricity, i can quickly sharpen the chain and get back to work........
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51243)
UNUSED INDUSTRIAS...
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
Test Button (A47384)
1997 Wells Cargo Enclosed S/A Trailer (A50324)
1997 Wells Cargo...
