Chainsaw has no power and blowing oil from exaust
   / Chainsaw has no power and blowing oil from exaust #21
Well the dealer says no & no.
No compression release made.
Head to thin to drill & tap.
Idea #3 (give or take a little). First I get a new spark plug. Take the old 1 and grind a small groove in the threads. Then see if works & if the engine changes.
Modern spark plugs only seal on the gasket & not the threads.
Only out a little time & 1 old spark plug.
My 372 with compression release is easier to start than my 55 Rancher. The old Rancher has very good compression
   / Chainsaw has no power and blowing oil from exaust #22
It worked!!!
I cut a small channel in all but the last 2 threads of the old plug. Turn out about 3 or 4 flats on the plug and it cranks real easy.
Prime, set choke, set throttle & pull through a few times. Couple of pulls and it is running. Close choke, pull throttle & clear out the engine.
Once warmed up, as normal it starts pretty easy.
Snug up the spark plug & its good to go.
Now to sharpen the chain. :laughing:
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
LOT: (4) Barrel Hand Pumps (A59076)
LOT: (4) Barrel...
20800 (A56859)
20800 (A56859)
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
