Chainsaw has no power and blowing oil from exaust
   / Chainsaw has no power and blowing oil from exaust #21
Well the dealer says no & no.
No compression release made.
Head to thin to drill & tap.
Idea #3 (give or take a little). First I get a new spark plug. Take the old 1 and grind a small groove in the threads. Then see if works & if the engine changes.
Modern spark plugs only seal on the gasket & not the threads.
Only out a little time & 1 old spark plug.
My 372 with compression release is easier to start than my 55 Rancher. The old Rancher has very good compression
   / Chainsaw has no power and blowing oil from exaust #22
It worked!!!
I cut a small channel in all but the last 2 threads of the old plug. Turn out about 3 or 4 flats on the plug and it cranks real easy.
Prime, set choke, set throttle & pull through a few times. Couple of pulls and it is running. Close choke, pull throttle & clear out the engine.
Once warmed up, as normal it starts pretty easy.
Snug up the spark plug & its good to go.
Now to sharpen the chain. :laughing:
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
More info coming soon! (A56858)
More info coming...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
