Chainsaw, fuel problems, inexperience......
/ Chainsaw, fuel problems, inexperience...... #11
That saw has a diaphram in the carb that pumps the fuel, it also has a small pulse tube (rubber) that is attached to the carb and the crankcase. If the tube or diaphram is bad it will not pump fuel. The diaphram gets weak or a small hole will start in it and that makes them hard to start if at all.
/ Chainsaw, fuel problems, inexperience...... #12
I just had "hard to start problem" with my Stihl Chain Saw. I was very busy and did not think that I had time to fix so I dropped it off at the dealer to have him fix it. Two things were wrong 1.) old gas - even tho I had used stuff do protect against this and 2.) Clogged fuel filter. He replaced the filter and put in fresh gas and everything worked great. The dealer said that these smaller engines suffer from old gas much more so than a lawnmower.
Leo
/ Chainsaw, fuel problems, inexperience...... #13
You have to clean all of the carb passages, even the little bitty ones, including under the welch plugs. Set the mixture screws at 1 1/2 turns.
/ Chainsaw, fuel problems, inexperience...... #15
Mith, I work on 2 stroke trimmers, chainsaws, etc. on my time off. 1st change old gas if applicable, check fire in plug, if compression is good and fire is good, then check diaphram in carb., if it is any bit brittle, change it, get carb. kit at lawn service either a Walbro or Zama, the number will be on the outside of the carb., but just bring it to let them see it. Clean all ports in carb with wire from wire brush, just take one out with needle nose pliers, run it through all holes. Make sure you take out needle valve and screens, watch little spring it will bounce. Do all of this in wide open space, cement floor preferably in case you loose something. If you have compression, fire, and gas it should work. Be sure all gaskets are in place and have no type of air leaks or are not stopping or covering up any intake holes. Also one other thing taht will not let it run is a stopped up exhaust. Take muffler off and check screen, it may be plugged up. Try to run it with muffler off.Let me know if this helps. Good Luck
Thanks for all your suggestions
havent got round to doing it yet, gearbox broke on one of the mowers, hopefully next weekend
thanks for your help
/ Chainsaw, fuel problems, inexperience...... #17
Mith,if it's a Stihl chain saw, you might look at the pulse tube which runs from the crankcase to the carburetor. This tube looks like a small fuel line with accordian folds in it and it's job is to provide vacuum pulses to the carb for the fuel pump. I've seen a couple of these crack which causes your initial problem( siezed top end) and won't allow enough vacuum pulse to pump fuel. Something to look at if it's a Stihl.
RIG MATS (A60736)
RIG MATS (A60736)
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
1042 (A60430)
1042 (A60430)
2024 Linx 7'X12' UT357714T Single Axle Trailer (A60463)
2024 Linx 7'X12'...
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A60736)
2012 BRUMLEY...
