caver
Veteran Member
- Joined
- Dec 20, 2006
- Messages
- 1,619
- Location
- Southeast Missouri
- Tractor
- Fisher Price, toddlers first tractor.
I just thought I would share an issue I've been dealing with for the past year or more. When I make the 120 mile run to my property I often throw both saws in the F250 bed. It rides like a log wagon. Often I get over there and neither saw will start. One is a Stihl the other a Makita (Dolmar). Often if I pull the plug it will be wet. I've also discovered on both saws there is noticeable pressure in the fuel tank. The elevation change in that 120 miles is about 500 feet. The Stihl got so bad I had the local dealer/coop look at it but it was a separate issue of needing the carb cleaned. The other day the Makita wouldn't start and my Stihl was about 200 feet away where I had been working. Once again a wet plug but after cleaning it did not give me any sign of life. Hmmm maybe there is pressure in the tank and sure enough like opening a soda can. I'm slowly figuring it out but lucky enough my property neighbors are far enough to not hear the flood of you %^&*-ing piece of &^%$ saw out of my mouth when one won't start.
