Chainsaw brands, full time vs. part time.....
/ Chainsaw brands, full time vs. part time..... #21
Cost per year is interesting however the useful figure on the value of the saw is cost per operated hour. In 6mo I put over 150 running hrs on a saw. I live in a burn scar and am clearing trees, so my workload is a little higher than the avg and after all the trees are dropped I wont be running the saws as hard. If you really want to see the difference in saws, even between huskys homeowner lines and the pro level saws run them this hard. Folks who have come to help me, who have homeowner level saws tend to either have problems or need work after a couple of good 8 hour days dropping and limbing trees. I have 2 saws in my shop right now that need repair. A homelight for an oiler and a small husky for a throttle linkage. The small husky Id say is a fluke. The homelight is because they use a plastic drive gear for the oiler. It just gets stripped off and stops oiling. I'm getting good at the oiler though since this is the second time Ive replaced the oiler on this saw. Its still way more of a PIA than my 550XP to take apart and put back together.
/ Chainsaw brands, full time vs. part time..... #22
I had an uncle that gave me chain saw advice when I was helping him clear some land as a teenager, using my dad's POS Poulan, which always seemed to be out of tune. He said "When you buy a chainsaw, you buy the biggest and best chainsaw you can afford, and you'll never be sorry."
About 10 years later, I was looking for a chainsaw. After seeing a buddy's Husqvarna start on the first pull, idle flawlessly, and never fail to perform, I bought a 55 Rancher. The Rancher was the smallest saw in the line at that time that was still made in Sweden. (Black tag on the front of the saw.)
Since then, it's been a trail saw for four wheeling, built pole barns, helped friends and family put up firewood, cleared storm downed trees, and never failed to start by the 3rd pull. It's 15 years old now, and since moving west a few years ago, it's mostly sat on the shelf. I pulled it out the other day to cut up some firewood. It hadn't been started in a year. 3rd pull and it was running. I learned to tune the carb, sharpen the chain, and give it some love occasionally. As I start the process of clearing land to build a home, I'm sure I'll be able to rely on my old Husqvarna.
I saw a really old bumper sticker a long time ago, on the back of a rotted out old Scout in the UP of Michigan...
"It's hard to be humble when you own a Husqvarna Chain Saw"
That's my story, and my advice. ;)
/ Chainsaw brands, full time vs. part time..... #23
Pro grade saws are lighter and put less vibration into your hands and arms so are easier to use for hours at a time. They also last much longer as in hours of use for the dollars you paid. As with anything else you usually get what you pay for in the end.
/ Chainsaw brands, full time vs. part time..... #24
I have a Stihl MS260 (mid sized in there pro lineup saw) Plus Echo's used as pole saws and many other jobs. The Echo's get lots of use per year. These are quality tools which I would not give up. A good tool is worth the extra cost.
/ Chainsaw brands, full time vs. part time..... #25
just to sum it up, I had a cheap Poulan and sawing wood was work got a Stihl and sawing wood is fun. the more expensive models have toque that will "pull" you through the cut...the cheap ones make you work.
/ Chainsaw brands, full time vs. part time..... #26
I mostly use a Stihl MS251-BCE with a little 16" bar. It is a nice, little saw that handles well, starts easy, and because it requires no tools to adjust the chain or to swap out chains, I'm inclined to keep my chain well adjusted and swap out chains when they go dull. A MS251-BCE can be picked up for less than $400.00.
/ Chainsaw brands, full time vs. part time..... #27
The cost per year on my 353 is currently about $23 per year. I spend more than that per year on chains, oil, and fuel. If I didn't burn wood I wouldn't have enough use to justify keeping the tractor. That makes the saws cost seem pretty minimal.
/ Chainsaw brands, full time vs. part time..... #28
I bought an ms361 used for $400. Used it for about 4 years and sold it for $500. So, I guess my annual cost was -$25. Not too bad in my book. My Shindaiwa 488, stihl 460, and Stihl 660 would all be easy to sell for as much or more than I paid for them.
/ Chainsaw brands, full time vs. part time..... #29
I had one of those my first ten years making firewood but then it fell off the trailer and got ran over. It still cranked afterward but it ran too hot with so many fins missing to cool it down otherwise it would still be going strong I am sure.
I bought a Echo CS500p a couple years ago, its the exact same saw as that old Shindaiwa 488, very reliable little saw and not quite as pricey as its match in the Husky or Stihl roster.
/ Chainsaw brands, full time vs. part time..... #31
Boy you guys are getting off cheap. I had a $400 Echo saw and had it for ten years and a tree fell on it. Bought another $400 Stihl saw which I still have and it still works. A couple months ago I sprung for a $625 Echo to finish the lineup and a small saw for limbing.
But then I had to have a JD tractor for hauling logs out of the woods and then a GN trailer to haul firewood home because I'm not getting any younger and needed to make it easier.
So I figure I burn 4 cord a year max with my new $5000 fireplace for about $44500 over a 20 year period. It is costing me $2225 a year to burn wood what would cost me $800 a year on LP.
But I like to do it?? :dance1::dance1:
You want another kicker.... you could work at McDonalds or Walmart for a couple weeks and pay for your heat bill for the entire year. ;)
Just thought I'd throw that out there to make everyone that heats with wood more happy (myself included).
Think I should of been more clear, already have a saw Husqvarna 550xp, paid $500.00+tax back in the spring of 2013, it was a replacement for a I think a 246xp I had. At my welding job, sometimes the subject of chainsaws comes up, this guy I work with tell's me how much he's liking this cheap $110.00 Bluemax chainsaw bought at Amazon couple years ago, starts everytime, idles when he sets it down.........but also says he's just a part time saw user.
Next time I get a chance, I'm gonna try one of these chinese saw's next to my 550xp, I had several saws, and have several brands, but so and pound for pound, I dont think there's a faster cutting saw on the market, not only that, the adjustment nuts stays on the cover............now I have to go back and finish reading these interesting post, I'm a slow reader.
/ Chainsaw brands, full time vs. part time..... #33
I paid $60 for that 488. It came with a gallon of bar oil and three brand new chains. It's a very reliable saw. It's absolutely never failed start. I just bought a parts saw for it which included a cylinder in pretty good shape and a fully adjustable carb, which my original saw didn't have. I figure once I get some spare time this winter I'm going to try my hand at porting it.
/ Chainsaw brands, full time vs. part time..... #35
I bought a $650 pro Stihl limbing saw, MS201T and it made me mad for 3 years. Always 3 or 4 pulls to start (at least). I bought it against my Husqv buddy's advice. He had given up on Stihl a few years prior,. He razzes me all the time. He always looks at me and smiles when his Husqv starts on the first pull, every time. Then a few months ago I got on the internet and figured out how to hotrod it and at least I like it now. It starts better too.
Stihl made an upgrade for the MS201T after a year or so; but they wanted $200 for the kit. I already paid premium price, why don't they take back their junk parts and just make my $650 pro saw work? I don't think I'd buy another Stihl.
I have an 028 AV Super that I like. The coil went bad, no spark intermittently. After it died completely then no spark period proved it was the coil. New coil solved it instantly.
My buddy's gone to 40v Electric (Husqv) for limbing though. His crew always fights over who get the electric saw. So much easier than a gas saw for many things, especially occasional use. You'd be surprised how much time is wasted with gas, starting, putting hearing protection on and off, its huge. Electric is probably not better for routine firewood cutting. But the electric saw makes my $650 MS201T look cheap.
You can get super high quality from China, but it usually costs a lot more than the cheap stuff. Can't tell just by price though, some things cost more simply because more money was skimmed out of the deal.
/ Chainsaw brands, full time vs. part time..... #36
My heat bill is over $300 a month if I don't burn wood, and that's heated 10 degrease cooler than if I was burning wood. That's not a McDonald's salary.
/ Chainsaw brands, full time vs. part time..... #37
I
m just going to leave this here for you.
2'' chainsaw shootout. Craftsman 5cc,Stihl ms271 Farmboss,Bluemax and Husqvarna 45 rancher - YouTube
/ Chainsaw brands, full time vs. part time..... #38
Exercise to keep fit, getting out of the house, and getting outdoors, and some fun factor. Hard to figure in a price and all a big win. Like your math !
/ Chainsaw brands, full time vs. part time..... #39
X2, that's why I get firewood.
/ Chainsaw brands, full time vs. part time..... #40
