Chains chains on an M7040
/ chains on an M7040 #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
wondering if I have enough clearance for chains since looks like with the ag tires very little clearance is left between the tires and fenders? Has someone looked into this?
/ chains on an M7040 #2
Not sure if this helps, but I run double ring chains with chain tensioners on my M9540 without any problems. Granted your rear tire size is 16.9-30 and mine is 18.4-30, though the fender spacing looks similar.
-CobraAH1G-
/ chains on an M7040 #3
I wondered about the clearance issue with my L4400, but there is plenty of clearance even with the chains I have with boron caulks about an inch long. Also there would be more clearance if I moved the tires out to their furtherest position, but in the winter I have better room in tight quarters when plowing. Here are some pics :
http://www.tractorbynet.com/forums/kubota-owning-operating/91299-winter-chains.html
Not sure what will happen when the chains pick up a big hunk of frozen mud and carry it around the wheel well, or when a branch getws picked up by the chain.
simonmeridew
