Chains, hooks, binders, straps 10,000lb+ load
   / Chains, hooks, binders, straps 10,000lb+ load #1
mtwashingtonhunter
Mt. Washington, KY
2015 Mahindra mPower 75
I'm about to purchase a tractor that's going to weigh between 10k-12k... My biggest fear is making sure I get this tied down properly. My farm is about 60 miles from my house... Plan on making this trip about 8-12 times a year hauling the tractor.
Anyone have some advice they'd like to share, examples of what not to do? Pics would be great.
It will have loader and cutter... I'm guessing I can get away with 4 chains and a couple-few straps?
I'm sure I'll overdo it the first few times, but would love to hear where I can buy the best chains and binders.
Does Harbor Freight offer ones that are reliable?
Home Depot or Lowe's?
Should I look at places that sell trailers? Tractor dealers sell them?
Appreciate any and all advice.
The tractor will be delivered soon and I'm hoping I can see how it was tied down upon delivery and take pictures and learn from that as well.
Thanks
   / Chains, hooks, binders, straps 10,000lb+ load #2
Thanks
Been using my harbor freight chains and binders for a while. That are nice and heavy duty for my application
I wouldn't go to any sort of dealer unless you want your money raped from you. You might try northern tool
   / Chains, hooks, binders, straps 10,000lb+ load #3
Anything over 10K requires 4 tie down points, 2 front & 2 back plus each implement such as loader or 3 pt. equipment must also be tied down.
I just took my tractor off the trailer or would have snapped some pics. My tractor with loader, loaded tires, and 3 pt. implement only weighs about 5600 or so but I still use 4 tie downs plus implement tie downs. I use 5/16 grade 70 chain and ratchet binders. For your tractor weight you may need 3/8". Some people cross the chains but I don't. As long as they pull at an angle the tractor doesn't move. I always put the tractor in the lowest gear range and set the parking brake. I bolted 2 D-rings to the front frame of the tractor for chains tie points and use a twisted clevis in the draw bar for rear chains.
Chain can be bought at any of the places you mention as long as its grade 70 (gold color chain). Others may use wide ratchet straps but I found they tend to fray and get cuts over time which compromises their integrity.
   / Chains, hooks, binders, straps 10,000lb+ load #4
Agree with the above. 4 tie downs on the tractor, grade 70 transport chain from your choice of stores, make sure the hooks are grade 70 as well. Ratchet binders are safer and easier to tighten than boomers. Your choice of chains or straps for thr loader and mower. 2" HD ratchet straps work very well, just protect them on the corners.
   / Chains, hooks, binders, straps 10,000lb+ load #5
As to grade 70 chains. Look at the links for the stamp. Gold or not in color; if DOT looks at them and they do not see the grade stamp then they classify them not as 70 or 43 but 30. A lot of the HF chain is marked as 43 but has no stamp on the links. I have seen HF "grade 70" chain without the grade stamp as well. Some has it some does not. Buyer beware!
I will repeat DOT considers it grade 30 unless they can find the stamp on the links. Every 3rd link or so is often where it is found stamped.
   / Chains, hooks, binders, straps 10,000lb+ load #7
Like the others have mentioned use grade 70 chains. With that said this is what I would do, four chains and binders for the tractor, one over the loader, and one or possibly two over the cutter depending on size. A 10-12k pound tractor plus a cutter is quite a load what truck and trailer aren't you using?
   / Chains, hooks, binders, straps 10,000lb+ load #9
I'm echoing the other posters:
Grade 70 chain, ratchet binders and 4 independent tie towns on the tractor (frame or axles, not loader or 3 pt hitch arms!) as well as a minimum of one tie down (I use 5000 lb rated straps) for each implement. The requirement is that the implements be secured, even if attached to the machine.
Even for a short run, pull over during the trip and check the tension on the binders. They will loosen as the tractor bounces around.
Thanks crashz! Picking up tractor Friday...have until then to get all my tie downs together.
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
Year: 2015 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 53,992 (A50324)
Year: 2015 Make...
New Holland 939 3 Row Corn Head (A50774)
New Holland 939 3...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
