Chains chains for 224 Jinma???
/ chains for 224 Jinma??? #1
cmperry
Maine
Jinma 224 (sold) Kubota B-7510
Hello everyone,just wanted some info on chains for a Jinma 224 4x4 3cylinder with turfs...the rear fenders look real close to the tire and was wondering if the chains will work without damaging the fenders. If they will work some contact info on a supplier would be helpful also....need chains for snowblowing and "skidding" trees...thanks everyone
/ chains for 224 Jinma??? #2
I have a 224 with turfs and chains. The chains are for a truck/bus tire size 9.00 x 20 tire or 10.00R 22.5 (basically the same size tire). I got mine for free from a buddy. They work pretty good and I have no complaints. I do have my rears a installed to the wider size just by swapping the wheels. I used it all winter and had no clearance problems as long as you make sure chains are tight right from the start.
I'm sure you can just type in a search for tire chains and come up with many web sites that sell them. They do not work well on Ag tires as the chains sit low in the lugs and make little advantage.
Take a ruler and measure the circumference of a tire and get approximate width and give them a call.
Here is a pic of my chains.
here's one http://www.tirechain.com/
thank-you Harry,I was mostly concerned with the chains hitting the fenders and it sounds like you haven't had any problems with that..I'll go ahead and try to get some bought...thank's again!!!
/ chains for 224 Jinma??? #4
are your fenders metal - or fiberglass - or plastic ?
//greg//
Hi Greg...they are fiberglass..held up good so far (100hrs)
/ chains for 224 Jinma??? #6
</font><font color="blue" class="small">( Hi Greg...they are fiberglass..held up good so far (100hrs) )</font>
Ok. Your business then, but I personally wouldn't even consider chains for anything but metal fenders
//greg//
/ chains for 224 Jinma??? #7
Mine are fiberglass and I measured 3 1/2" clearance between tire and fender. I got mine tight to begin with and did not have any problems period. They are great when its icy BTW. End of story.
/ chains for 224 Jinma??? #8
How many hours do you have on your tractor Harry? I've got about 230 on mine and except for the earlier problems around that deaded 50 hr mark, it's running great..Take care...
/ chains for 224 Jinma??? #9
John, great to hear from ya.
I'm at the hunderd hour mark. I guess she is still a virgin.............. /forums/images/graemlins/grin.gifLOL....I don't use mine as much as you do with two properties. I do have two tractors so that keeps my hours lower also. I have been so far satisfied. No leaks whatsoever that many complain of. I only wish my car had had so little leaks. LOL.
/ chains for 224 Jinma??? #10
"except for the earlier problems around that deaded 50 hr mark"
I will be comming up on that 50 Hrs mark some time this fall; What do you run into ? /forums/images/graemlins/mad.gif
/ chains for 224 Jinma??? #11
I thought I had blown a head gasket or cracked block because as I was pulling HUGE stumps around at my property the temp gauge when up real quick. After checking the coolant in the radiator I didn't see any. Then I pulled the dipstick for the oil and it was to the top with a little green on it. Well long story short, changed the head gasket and a few other things and the tractor has been running like a Bull. Didin't even retoque after the next 50 hours which would have been the 100 hr mark after the new head gasket. It runs stonger and looser now that its broke in. A lot of minor leaks here and there but I think most of it was over reacting.
I have a lot of pics on my website of what this Chinese tractor that cost the same of a decent Quad has done for me. Few streeful moments of lurking in the unknown but great support to pull you through and then you realize it really wasn't anything major...
Check out some of the work my little 2 cylinder 224 has done.
http://users.adelphia.net/~gizmo/
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
2024 CATERPILLAR CP56R PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
Air Hose Reel (A65640)
SELF-PRIMING CENTRIFUGAL PUMP (A65643)
SELF-PRIMING...
John Deere 772-A Grader (A62679)
John Deere 772-A...
