Chains and block heater for Satoh Beaver
   / Chains and block heater for Satoh Beaver #1
ssg510
I need a set of chains for my s370 beaver does anyone know where I can get some. Also is there a block heater or a way to heat my tractor during the cold season. Thanks for your help.
   / Chains and block heater for Satoh Beaver #2
My Beaver had a block heater (freeze plug type) installed when I bought it. That type of heater is available online. Google it and you'll find 'em. Mine also had chains, saving me a bunch of money! Check your rear tire size and Google tractor tire chains and you'll find those. There are also some dealer who monitor the forums and may chime in with parts availability and advice.
Don't know where you're located, but I'm in Pennsylvania and even with our relatively mild winters the block heater is almost a necessity!
John
   / Chains and block heater for Satoh Beaver #3
All you need to knw is what size the freeze plug is and put in a block heater. I installed one in my MT372D. It's behind the starter. Very easy install.
Mine is hard to start when it's below 50.
I would look for chains on E-Bay or locally. You only need the tire diamater to determine what size. If you got a size too big, they can be cut down to fit. Makes a big difference in traction.
   / Chains and block heater for Satoh Beaver #4
Just put a block heater in mine this week. I have a MT180HD. The freeze plug was 44mm and I got the heater from an online Case/IH dealer. My tractor is the same as the IH 234.
Greg
   / Chains and block heater for Satoh Beaver #5
On the MT180 the heater replaces the frost plug just below the oil filter.
BE SURE TO SPECIFY 400 WATTS as the 200's just don't cut it.
Any auto parts should be able to supply at less than $20.
Another member said that he purchased for a mere $5.00. (amazon, I think)
   / Chains and block heater for Satoh Beaver #6
I found chains on craigs list for 125.00 a pair.Will fit tires 52in high x 16in wide.I am located in NE PA,if they are close in size you can trim them.
   / Chains and block heater for Satoh Beaver #7
On the MT180 it is actually the Freeze Plug just ABOVE the oil filter.
Greg
2019 Dodge Durango (A53421)
2019 Dodge Durango...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2020 Exmark ECX180 21in Push Mower (A52377)
2020 Exmark ECX180...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
