Chains....Age old question...need some advice
   / Chains....Age old question...need some advice #31
I believe that we have a difference in counting here,
that is what I would consider a 2 link spaced chain.
Here is a picture of an advertised two link spacing;
I had two link spaced chains on my Oliver, no comparison to the Euro studded type.
OK, I fold LOL, we are all talking the same configuration!
That is what I use on my CUT.
Nice ride and no slipping.
When I re configured I did run out of the hardened cross links and completed my build with welded V type as that was all that was available locally.
Years later the V type hardly exist while the hardened stud types show hardly any wear and I only drive on snow covered gravel roads and not all that many hours either, guessing perhaps 2-300 at best.
   / Chains....Age old question...need some advice #32
I find the "V" bar seams to wear really quickly, at least the edge. Once worn down they are basically just like regular chains. I install them in a similar way to Piloon. I jack up one wheel, put the tractor in 2wd and neutral. I lay out the chain behind the wheel and hook the edge of the chain onto the tire then rotate it. Once I get to where the ends are in the 3 O'clock position (looking at the wheel from the side) I put the tractor in gear so the tire can't rotate and then I connect up the center chains and then tighten the outside chains. But I have ag tires so the chains hook on real easy.
I also put the chains on tight even though they say to do it loose. That way there's no way they could hit the fender if one wheel decides to spin faster than expected. Also I've never had to deal with rubber straps to keep them tight or having one fall off. I can do each tire in about 5 minutes but that's because my chains came with two styles of connecting links for the center chains. One has a roll pin to keep it on the chain while the other has a T shape at the end of the C shape. To get it to pass through the end link on the chain you have to turn it sideways. But there's no roll pin to deal with so it's very fast.
   / Chains....Age old question...need some advice #33
I'll have to give that a try. What I've been doing is laying the chains out on the ground and backing the tractor onto them then working the chain over the tires. Does the job, but the older I get the heavier those chains get!
The tricky part is the timing...getting them on before the first snowfall (few things in life match the joy of laying in slushy wet snow putting chains on a tractor), but not so early as to limit other things you might want to do with the tractor.
Can't say I've had much in the way of wear, and mine are V-bar, but I have a gravel driveway so that may make a difference. Only time I'm on pavement is maybe 1/4 mi each way to do my next-door neighbor's driveway.
Mine seem to hook pretty well, and I have R4's.
   / Chains....Age old question...need some advice #34
Yes it's so much fun when you have to take your gloves off to try and get things aligned and fastened,
putting them in pocket to get warmed back up.
Then reaching and pulling on cold steel and have bits of skin stick to the steel and peel off.
I try and get at least one tractor chained up early enough just in case,
sometimes it works some times it doesn't.
   / Chains....Age old question...need some advice #35
Yeah, that's the hard way. I did it that way for a few years until someone tipped me off to driving them on.
I rarely seem to call it right as far as when to get the chains on. Fortunately, driving them on involves much less crawling around in snow. Still not fun, but a lot more tolerable.
   / Chains....Age old question...need some advice #36
Another option for you: I found chains for my Kioti CK2510 within pickup distance of the NH Bluehills, in Union, ME: Union Farm Equipment | Kubota Dealer in Union, ME
I took delivery of the tractor in late December two years ago. I'm on a private road with mixed gravel and pavement, driveway slopes with tight plowing and bucketing needs. Impending snow required a quick decision. I read numerous posts on this forum, shopped online sources for the various chain styles, then found UFE. A quick call verified the chains were in stock, the price was good, and 2.5 driving hours later I had them in hand. I believe I have the 2 link spaced ladder style chains, and picked them up for the rear wheels only.
I had an experienced tractor owner help me install them that same day in preparation for the storm. He installed them a bit loose with rubber strap tensioners spaced around the inside and outside of the chains. I found the loose slack allowed movement of the chains on the tires during that first season with occasional slap of the inside of the fenders. I installed them tight to the tires last year and found they worked much better with no practical movement over the season, and no slap. These chains have worked great and my neighbors have reaped as many benefits as I have!
   / Chains....Age old question...need some advice #37
I ordered mine through my local ag tire shop. V-bar/studded H pattern is what I settled on, and I'd buy the same again.
Biggest problem is installing them. The chains for my rears are well over 100# per side and it's really a two person job to get them on.
Cheap option would be getting a few sets of truck chains from a scrapyard and joining them together.
   / Chains....Age old question...need some advice #38
Is this the pattern you are talking about:
The style is known as "Duo Grip". It works well for both forward and lateral traction. It can be a bit of a rough ride when running on paved roads or other hard surfaces if you are trying to move at higher speeds (especially with filled rear tires). They do provide good traction and are great off road significantly better on side hills than ladder style chains.
The "Drive it on" method of installing chains described earlier in this thread works well for installing them. You may want to modify it slightly: Instead of tying the string to the side chains, tie it near the middle of the end cross chain (when I had Duo Grip chains, I ended up tying in one end of the string several inches off-center of the cross chain, and the other end of the string several inches off-center in the other direction. This a good job of holding the chain centered on the tire, and still let me make easy connections on the side chains once I got it pulled around the tire.
   / Chains....Age old question...need some advice #39
If you just drive them on it isn't a bad job, I can chain 20.4-42's by myself.
   / Chains....Age old question...need some advice #40
Deereman75,
See post 20, 21 or 33 for the link to Lou’s easy one man installation thread.
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
2021 DORSEY 53FT FLAT BED (A58018)
2021 DORSEY 53FT...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
1449 (A57192)
1449 (A57192)
2019 Freightliner M2 106 AWD Altec AM55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
