Chain sharpening
   / Chain sharpening #81
I don't know if the Stihl Pro chain I have seen referred to in this discussion is the same thing in the USA but here in Europe Stihl do a tungsten chain which although you can't sharpen yourself (it needs a dealer who has an expensive diamond equipped sharpener machine) the chain last ages. I got a couple for my 18" and 14" Stihls at the beginning of last year. They are still cutting fine and although I haven't tested it are supposed to be tolerant of touching soil. In fact there is a Stihl YouTube film which compares an ordinary Stihl chain with a tungsten one sawing a log filled with sand. That said, I have yet to find a Stihl dealer round here who can sharpen the things but I may decide just to buy new again when they pack up.
   / Chain sharpening #82
They have a lil pack that has a file and a guide to keep you on the right angle and wont let you go deeper than need be. Works good. Sharpen my chain in 3 minutes probably. Like to go deeper than the drag guide lets you file them
   / Chain sharpening #83
They have something similar here that the fire departments use on their chainsaws that they use to cut through roofs and such. Spendy, but when you need it, you need it.
Aaron Z
   / Chain sharpening #84
For what your using your saw for, I would think 2 or 3 passes with a hand file every tank of gas would suffice in keeping the blade tuned.
For more in-depth sharpening, I use a dremel with carbide bits I bought off amazon. A 5 pk for $4. I don稚 use a guide because I I do this quite often and have developed a feel on field dressing chains.
   / Chain sharpening #85
Aaron Z
Most of the fire saws that I have seen use Rapco brand carbide insert chain.
   / Chain sharpening #86
I've yet to try square ground. The files are insanely expensive and I already know how to file and grind regular chain. If I cut a lot of big wood I'd be more inclined to try it.
Let me help you out with a decision as I learned to use square ground for one type of situation and one situation only and that was for "felling". Nothing cuts faster than square ground and nothing dulls faster as well.
When we were harvesting mill wood, I would for the most part attempt to use square ground as I know I would only be felling and sawing off crowns. On firewood days, I could not substantiate its use as it dulled too quickly in bucking skidded wood. It was just too much of a pain to keep up with including the sharpening so after awhile, I stuck solely to semi-chisel.
   / Chain sharpening #87
For occasional use and a low learning curve I' suggest this:
2 in 1 Filing Guide & Saw Chain Sharpener | STIHL USA
I'll second this. Actually, I've been through quite a few different sharpeners and this is the only one that I've found is worth using. Not hard to use in the field either. I stay away from powered units because I worry about removing too much material. In general, it's best to be touching things up as you go, much like a professional chef will always be steeling his knives as he works.
I can cut up a LOT of wood before I need to sharpen: not cutting the hardest wood, maple, but not exactly soft either- type of wood make a big difference. I'm running a Husky 562XP (modded) with an 18" chain (Husky chains- got a great deal on a pile of them). Pretty much as long as you keep them out of the dirt they'll cut well for many cuts.
   / Chain sharpening #90
6' ROTARY MOWER 3PT W/ FULL SHAFT (A57192)
6' ROTARY MOWER...
2021 Billy Goat F902H Walk-Behind Debris Blower (A55851)
2021 Billy Goat...
2002 Henderson FSP Sandspreader (A55973)
2002 Henderson FSP...
2014 Ford F250 (A55973)
2014 Ford F250...
UNUSED WOLVERINE TD-13-36R 36-48" TREE DIGGER (A57193)
UNUSED WOLVERINE...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
