Chain sharpening
   / Chain sharpening #61
I think chain sharpening is the new best oil thread. Or HST vs Gear thread. :D
At least it isn't about which is the best rifle for deer hunting. :laughing:
   / Chain sharpening #62
My solution to keeping logs out of the dirt when cutting into firewood sized logs. Of course now that I have pallet forks for the tractor, not sure if I will use them to load this or just cut from the forks.
I love this rack though. Buck your trees into 8' lengths. The you get to stand up straight while cutting, it keeps the logs at the exact place for cutting them to the correct length and it keeps them pinned in a cage so they can't move while cutting.
   / Chain sharpening #63
I've thought about building something similar to fit over my ATV trailer. I have a lot of small hardwood (2-3 inches), it would be nice to reduce the handling.
   / Chain sharpening #64
Also don't forget to grease your bar tip.
Not really necessary. Once you do grease it, you need to keep greasing it to push out accumulated dirt that becomes stuck in the grease. Most of the pros I know are in the "Never Grease It" camp. I'm not a pro, but I never grease, and I wear out a bar long before the sprocket in the tip fails.
   / Chain sharpening #65
The rule is grease it every time you use it or don't grease it at all. Some of the bars for Stihl and Dolmar/makita and maybe other brands don't even have the grease hole in the sprocket.
   / Chain sharpening #66
So my 2C. I live in the land of logging here in the PNW. Lots to learn from all the work around here. Most pro's walk with a mechanical file, and the stihl 2in1 is pretty popular. Pros are always putting and edge on the blade, and on a big big tree, they can sharpen acouple of times to get through (this is a quick, 3 pushes of the hand file). I think the guys might do it to rest but not look like they are resting to the boss, but logging is tough tough work especially in the hills we have. Anyway, a better blade (oregon or Stihl) wouldn't hurt. I use a Dremel to sharpen and have a harbor freight sharpener which is good enough for a homeowner bolted to a bench. I find I am now more happy with the dremel as I do not have to take the chain off. But sharpening a chain isn't super simple, you have to have the right angle, and you have to keep an eye on the whole chain (those nubs after the cutting tooth need to be kept in check). So once a year I used to take my chain to the local saw shop. Thought they had a fancy machine to sharpen my blades. Nope, they had a pro machine that was nearly identical to my harbor freight. Now I just do my own sharpening.
One other thing to keep in mind is why is your chain going dull. Dirt as mentioned kills a chain quick. Drag a log with your tractor, you just jammed dirt into it. Hit a part that is rotted out, more than likely you got some dirt there, run the tip into the ground, that will do it for you, for us Moss rots, turns do dirt, collects more dust in the summer, and then you cut through that layer and your saw blade is dull.
   / Chain sharpening #68
Most people will never see or even hear of square ground chain. Let alone having the capability to sharpen it when it gets dull. Oregon doesn't even have the files to sharpen square ground in their catalog, and definitely doesn't offer the sharpener for it. Silvey was the company that made most of the square ground electric sharpeners on the market, and they went out of business a couple years ago. There is another company that makes the sharpener, but it is still around a grand for the machine. Heck the square ground hand filing jig is over $200.
   / Chain sharpening #69
I have a Oregon 510A for sharpening, love it will not go back to hand sharpening. Got it from a friend who did not use it because it would not do his harvester chain, he has a Silvey that does everything he needs done.
For a while you could get the Oregon square ground chain around here by the reel cheep and then when it got dull, you just round ground it and went that way, the pro chains are nice and hard. You get guys liking how some of the new chains are good at being filed until they are told that that means they are softer and not holding an edge, some of the Carlton and Home Depot chains are really getting bad. Nothing like some of the hard chrome Stihl chains.
Guess Simington down in Lakeview is the only one left for square ground chain.
Home of Simington Chain Grinder - Simington Chain Grinder
David
   / Chain sharpening #70
I've hand filed for years and that works great for me, but I've been thinking of going with a better system. I've looked into those Stihl 2 in 1 sharpeners for awhile, and they look like the real deal. They are fairly priced from the dealers, easy to use, produce accurate sharpening while also keeping the depth gauges trimmed to the correct height. I plan to pick one up the next time I'm close to a Stihl dealer.
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2012 BAD BOY CLASSIC ELECTRIC GOLF CART (A57192)
2012 BAD BOY...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A55315)
2020 John Deere...
Emerson 18' Homemade Trailer (A56469)
Emerson 18'...
