Chain saw bar oil accidentially used in transmission
   / Chain saw bar oil accidentially used in transmission #1
RaymondEdward
Caledon, On
Kubota L 4740 Mahindra 5035 Kubota RTV 1100
I checked my hydraulic dip stick today and it was below the upper mark. I was not watching what container I grabbed and started to pour into the transmission filler port less than a cup of the chain saw bar oil in (its reddish colour, talk about stupid) and realized what I was doing and stopped, and then added the proper hydraulic oil to top up. I checked the dip stick again to see if the oil had a red tinge to it and could not see any discolouration of the oil.
In your opinion is this going to create a problem given it was a very small amount bar oil?
Come to think of it, it's very difficult to see the oil level on the stick because its so clear. Why don't they add a little colourant to the hydro oil so it's easier to see the level on the dip stick?
Thank you.
   / Chain saw bar oil accidentially used in transmission #2
No expert here but a less than a cup would seem to be a inconsequential. I guess if it were me... I would run a little test to see if the two mix easily and if they do, then sleep well.
Yup I was think of mixing a bit of each in a jar and see if they blend well. Will post tomorrow as to my findings.
Thank you.
   / Chain saw bar oil accidentially used in transmission #4
That small amount should not harm anything.
   / Chain saw bar oil accidentially used in transmission #5
Add a shot of Jack Daniels that should cure it.
   / Chain saw bar oil accidentially used in transmission #6
If your the type that won't be able to sleep nights worrying about it get a Used Oil Analysis for about $30.
Blackstone labs is one place.
My M4700 takes 10 gallons of Hydraulic, I wouldn't worry about a cup of thickener.
   / Chain saw bar oil accidentially used in transmission #7
Nothing to worry about.
Thanks for the replies. Considering how much hydro oil the transmission contains the chain oil is insignificant so I can sleep without adding Jack Daniels. ;)
   / Chain saw bar oil accidentially used in transmission #9
Assuming this is on one of the large tractors, then yea, a cup mixed with 10 gallons of oil aint anything to worry about. Less than 1%.
But in fairness, you didnt mention what it is on. A cup in the RTV may not be good, or anything that has a small amount of fluid. Or an auto tranny. But in a tractor, no big deal.
Oh, and they do make dye for hydraulic oil just so you know.
Hydrema 912HM Haul Truck (A52384)
Hydrema 912HM Haul...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
TEST YOUR BID BUTTON! (A51247)
TEST YOUR BID...
KISMILE HBZB-30N ELECTRIC ICE MAKER (A51248)
KISMILE HBZB-30N...
