Chain recommendation
/ Chain recommendation #22
Pulling logs and tree’s
The chain that you linked in the OP will work in a pinch, but there are significantly better options available to you. For skidding, you should look into wire rope chokers. They are a much better option for most log skidding applications. One of the nicest things about it is that you can push it under a log, which, of course, isn't possible with chain. Chain has it's place for skidding though. For that, you'll want a hook like this. 4 Pack 5/16" Slip Logging Chain Choker Hook Metal Log Hook with 2 Tons 4400 LBS | eBay
These hold the chain in place when you want them to and won't break on the first use like the latch on that one in your first link will. They're also very handy to have for other chain uses besides just skidding. I have half a dozen 9/32 grade 80 chains with a lift rated hook on one end and a slip hook like that on the other.
/ Chain recommendation #23
I'm a fan of the Twist Lock hooks. Chain, Hook and Rigging Accessories - BoltOnHooks LLC. They use to be a TBN sponsor I believe.
Bolt rather than pin, but either works fine. I like the latch so I can keep the chains on the trailer all stretched out. If you properly tighten chains on a load the latches are irrelevant. Handy for when you don't have them tight with a binder.
/ Chain recommendation #24
Seems like those might be subject to damage if used for skidding logs.
/ Chain recommendation #25
Ya, I only use them for transport or stuff around the yard. Threads & bolts aren't going to do well with skidding.
/ Chain recommendation #26
Yeah, seems like they'd be handy for some applications. The OP wants this chain for skidding though.....
/ Chain recommendation #28
I ended up buying this one cut the middle link out of it so I have 2 - 10 footers to use
Chain
Did that myself, bought 2 5/16 grade 70 20 ft.chains. Left 1 uncut, cut other in half and bought extra grab hooks. The 20 ft chain seldom gets used as the 10 footers are just so much easier to deal with.
/ Chain recommendation #29
20 years ago, I bought some Pewag grade 100.
This shows 120 but if memory serves me, I bought grade 100. What I liked about the idea of it (and LOVED it after put to use) was/were the square links.
I knew I'd be using it primarily for dragging logs or maybe pulling a stump out (I just dig them out as a practical reality)
I had used a normal, rounded chain before and seen it slip. Like hoisting a stump after dug out. The stump slips the grip. The square links essentially bite into the log and don't let it go.
3/8" Grade 100 might be over kill.....but I would be using it with an industrial loader/backhoe and later on, obtained a 125 HP (pto) tractor. I'd rather have over kill, than under.
I've never been able to break the chain however, I was once dragging a tree down my road. As it turned out, the weight of the (big) tree was directly on some links and where they interfaced between the log and road, got 30% ground away because of the friction. That was probably 15 years ago, still fine BUT I know that weak link is there. Thought about cutting it out but just keep going.
My International 1066 with 15' flexwing attached once got mired to the axle in mud on far side of farm. Called my next door neighbor asked him to drive the backhoe over there. He came and his friend was with him. I wrapped chain around the frame of tractor. stretched things out, attached other end to stretched out backhoe. I started pulling with the hoe while he was on tractor slowly letting clutch out. Got it out, his friend (who said he worked in some kind of steel sales capacity) he said he was just WAITING for that chain to snap given the load it was under. Nope, didn't happen and he left a believer.
I am a BIG fan of this Pewag stuff.
2019 FREIGHTLINER CASCADIA TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
2000 LINCOLN TOWNSCAR (A64278)
2000 LINCOLN...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
