Chain pitch (size) differences.
   / Chain pitch (size) differences.
Newbury: Madsen's guide bar and saw chain menu? That's GOLD right there. What a great learning resource. I also appreciate all the advice, from everyone.
I have little knowledge of chainsaws but want to learn. I'm also very respectful of their danger. I wear wrap around chaps and ear/eye protection.
I would guess that I've got 25-50 more trees that might be in danger. Don't know the DBH but would guess it to be between 16 and 20 inches.
FWIW, the reason I'm cutting them now is that I just got a stump grinder (you can see review in the attachments thread). I had a friend take down 11 trees last winter, a tree crew take down 15 this summer. The crew cut the stumps to about 6-10" above the ground. My friend cut them about 3' off the ground.
I could hire someone to come down and do it but, like hiring stumps ground, would be money gone with no future capability.
The stump grinder was heavily researched and some of the best money I've spent. I'd like to be as happy with whatever saw I might purchase.
Thanks, again, to all.
   / Chain pitch (size) differences. #22
Smoking means the chain was dull, independent of the cutter type. When sharp, RM should fly through locust (it does for me).
The chain was NEW and the locust trees had been dead for sometime.
   / Chain pitch (size) differences. #23
Just one more note to add for the OP -
Also consider getting a battery operated 40V chainsaw for those little jobs. I bought a B&D 40v for a little over $100 w/ battery & charger. I often get a few limbs down during storms, usually < 6" around.
To put them out on the curb they must be < 4' long.
The little saw is ideal for this application. Grab it, check oil and chain, don't worry about starting it.
   / Chain pitch (size) differences. #24
I think the bottom line is that cutting stumps is tough on a saw, bar, and chain, as well as the user. Bigger saws are a lot harder to handle. Smaller saws don't have the guts. Getting the saw power head close to the ground compromises air flow and cooling. It's really just a lousy job all the way around and there is no silver bullet (other than stump grinder or backhoe).
:thumbsup: And the dirt, pebbles, rocks one encounters too -No matter how careful you are trying to clean around it. As some mentioned, often embedded in the bark at that level.
Then there's the chips and saw dust that piles up at the saw and can clog everywhere, compromise cooling, etc..because you're so low to the ground.
On bigger stumps it's handy to use a (plastic) cutting wedge, or two, to prop the stump up so it doesn't pinch your bar as you get farther through it.
If I'm cutting down (or cutting up?) a tree, cutting the stump is the last cut of the day because I know there's a good chance my chain might be done for the day afterwards.
File often.
Thanks for all the help.
Based on your input and the way I was treated at the dealer, I went with the Husky 455 Rancher.
Fired it up, cut the stumps I needed to cut. Chain still seems sharp. Ground the stumps and everyone is happy.
I know it is not a "pro saw" but I'm not a "pro".
I'm very impressed with the way it cut.
Thanks, again, for all your input.
Life, indeed, is good.
   / Chain pitch (size) differences. #27
I've tried several brands of chain in sizes from a 10" bar to a 42" bar and found that Stihl brand chain was "harder". It didn't dull as quickly and required more effort to sharpen.
Same here. I run Huskys, but Stihl chain. It holds the edge better. I don't mind a little more sharpening effort.
   / Chain pitch (size) differences. #28
Husky 450. My little buddy can do more with one nut than some could do with three.
   / Chain pitch (size) differences. #29
Not sure what that's supposed to mean. If you had a 3120xp I'd agree.
   / Chain pitch (size) differences. #30
I think s219 is correct. I have many 4" to 6" trees that I need to cut low to the ground in a severely overgrown pasture. Has anyone tried a carbide chain for cuttng close to the ground. I'd be interested in knowing how well it worked out.
2006 TRANSCRAFT 48X102 SPREAD AXLE FLATBED (A58214)
2006 TRANSCRAFT...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
1698 (A58375)
1698 (A58375)
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
