chain harrow
/ chain harrow #1
tld
Boston, GA
JD 2025r
What size chain harrow for JD 4110, 20hp diesel?
/ chain harrow #4
(this was originally posted to a reply on CountrybyNet, but this forum has much more traffic)
Speaking of chain harrows, does anyone use the poor man's chain harrow.... a length of chain-link fence? How long? Do you use a log (or 4x4) on the leading and trailing ends? How do you hoist it for travel to/from the field?
I plan to use the skidder trails from a recent timber harvest as horse trails. I met my forester and timber cutter to lay out where the trails would go and how they would be connected. After the spring mud season, I plan to drag a chain harrow around to smooth out some of the slash and water bars left over from the operation. I can also use it to break up the manure in the pasture.
/ chain harrow #5
I Use a ATV chain Harrow that I got from Cabelas. I have seen other use a old matteres and take off all the padding leaving the spings and wood frame. I have seen some use plywood on top and small bricks for weights. It looked like the set up really worked pretty good. Dave
/ chain harrow #6
I have a heavy 6x8 chain harrow, but a neighbor uses your idea.. one of the poor man ones. He took a railroad tie, and wrapped some chain link fence around it.. a few times. Has a chain to either end and drags it from his drawbar. Uses a boom pole to lift it.
I've been towing with making a rig to use my poom pole to lift my harrow. Right now I roll it up first, then lift it with the pole. Would be muche easier to leave it 'ready'.
Soundguy
/ chain harrow #7
[quote Speaking of chain harrows, does anyone use the poor man's chain harrow.... a length of chain-link fence?)</font>
Rozett,
I have to warn you about using a chain link harrow! If you have roots, sticks, or tough grass mixed in your soil, the chain links will clog in no time.
Mine became so clogged it looked like a monstrous big hedge hog. No salvaging it, as it would have taken 2 days to pull out the junk.
/ chain harrow #9
At $200+ your chain harrow will be cleaned if it clogs up. /forums/images/graemlins/wink.gif
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
