Chain harrow for pasture
   / Chain harrow for pasture #1
RoMad
Platinum Member
Lecanto Florida
Kubota L3710
I have been thinking of making a drag that I can pick up with my three point hitch. After looking at a lot of differnt styles I found one on youtube that is very close to what I have been thinking about. I was thinking of using heavy chain link or something similar for the part that drags. What I am looking to do is to spread out the manure in my pasture and to smooth out where I box blade.
3 Point Chain Harrows ::ABI Attachments::
   / Chain harrow for pasture #2
I have drag harrow without the 3 point hitch pickup. I pick it up with front bucket. Oops I popped a headlight moving it that way. A few hundred to fix that and still wainting to fix the headlight. Now I wish I had made a frame to move it from the 3ph.
   / Chain harrow for pasture #3
tsc makes those if you don't want to scratch build one.
soundguy
   / Chain harrow for pasture #4
I made this 3pt harrow for $250 and it would work well for spreading the piles in a pasture.
   / Chain harrow for pasture #5
Chain harrows work well for manure piles. You can get an inexpensive boom pole and some chain and make a harness to lift it.
I sometimes add a weight, a tire from a semi, if the piles need a little more force.
Thanks for the pics, I really like your harrow. Now that I have been reading more I want a chain harrow and one with spikes. I am thinking of making a frame very similar to the one in my link and then making a chain type drag and also a harrow that will be interchangable in the frame. I have some sketches made and will start it as soon as I finish my trailer project.
I have enough material to make everything I think. Today I was given a full 5 gallon bucket of railroad spikes to make the harrow spikes out of.
   / Chain harrow for pasture #7
This is something you might take into account with your design.
It is sometimes helpful with a chain harrow to pull it from one end or the other. The tines are more aggresive one way. Also, flipping it over to use the "flat" side sometimes works better with manure and burying seed that has been broadcast.
   / Chain harrow for pasture #8
I cut my harrow teeth out of 5/8" sucker rod, which is a good metal that resists abrasion.
   / Chain harrow for pasture #9
I'm looking at the 3pt 6ft from this place. Seems like the nicest designed one I've found. I have blacktop to go over before I get to were it's needed so the three point for me is the way to go. Price is high but it's the one that will work best for me.
   / Chain harrow for pasture #10
Steve
Thats an awesome looking attachment you made there ! :thumbsup:
8' x 4' ?
Boone
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
3 1/2 BLACK CONDUIT WITH ROLL OF FABRIC INNERDUCT (A50854)
3 1/2 BLACK...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
377780 (A48837)
377780 (A48837)
