Tires Chain front tires only?
/ Chain front tires only? #21
SPYDERLK, I dont know about a BX, but on my JD, I had the same clearance problem with the front tires. Chains wouldnt clear the tie rod on the right side unless I turned the wheel around. It makes the front stance a little wider than the rear, but it works quite well, and the dealer said it would be ok to do. You might try it and see if this helps.
/ Chain front tires only? #22
With the amount of snow we get, and taking into consideration of the stress we put on our FEL, I will not just run front chains. Too much to ask of the front drive line. Chain up all four, and let the tractor do what it is designed to do.....4x4.
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2006 Link Belt HTC-8675 75 Ton Hydraulic Truck Crane (A60352)
2006 Link Belt...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A61567)
2019 Kubota...
