CHAIN DRAG HARROW
/ CHAIN DRAG HARROW #21
mark.r said:
Anybody else have any feedback on one of these?
3 Point
I have great feedback, I made one about 15 years ago and it is the best all around harrow for lots of things, take a look at their site and you will see, mine is reversible with different depth spikes and I can pull it aggressive or smooth and I did pull this with a Chevy S-10 PU and I use my Case now. I made mine from used heavy rebar and it's still great and mine is seven and a half feet wide and about 5 feet long
Make one and save your money for other toys :D
/ CHAIN DRAG HARROW #22
ScottOkla said:
I ordered one last week and they finished it yesterday.
I should get it next week, and maybe try it out a few days after that. I'll post something then.
Any feedback yet?
/ CHAIN DRAG HARROW #23
Soundguy said:
It's likely your 3pt can actually pick up more drag that you can easilly drag... etc..
Ain't that the truth. I have occasionally connected an 8' chain harrow with our BX2350, when the larger tractor is occupied. The 3PH picks it up and I can go straight forward just fine, but it is awfully light in the front end. It doesn't turn so well! :)
/ CHAIN DRAG HARROW #25
ScottOkla said:
I am picking mine up tomorrow.
Excellent looking forward to hearing your thoughts. What size/model did you purchase?
/ CHAIN DRAG HARROW #26
I got the 6' wide model so I could transport it more easily between properties.
/ CHAIN DRAG HARROW #27
Thanks, I am looking at the 7 1/2 for similar reasons. Let me know how you like it.
Mark
/ CHAIN DRAG HARROW #28
Well, I finally got mad enough with tangling of my regular chain harrow and I bought the Delta Tooth one I referenced earlier.
It can't tangle (physically impossible)
it's VERY heavy and it blows up manure concentrations like you can't believe.
So far, (10 acres), I'm pretty happy with it.
/ CHAIN DRAG HARROW #29
Brian, a few questions if you don't mind. What size is your new harrow and how long did it take to harrow the 10 acres? Oh, and which tractor did you use?
/ CHAIN DRAG HARROW #30
It's a 6' wide by about 4' long, and it weighs a LOT more than my old style 6'x6'.
I pull the harrow with an ATV. Much faster, much less pressure on the pasture (an ATV with a fat guy on it, still weighs less than a tractor with or without fat guy. :) )
Took me about 2 hours to do 10 acres. About the same as the old style, but I'm saving that 15 minutes to untangle it after taking it off the trailer.
/ CHAIN DRAG HARROW #31
So 8 mph is what you would consider a normal speed to pull your harrow?
/ CHAIN DRAG HARROW #32
That'd be a good clip.. depends on the bumpiness of your pasture. if flatish.. go for it.. if ridged.. hold on!
Soundguy
/ CHAIN DRAG HARROW #33
No, I actually pull it at about 10 to 16mph.
Really (according to the ATV digitial speedo)
remember an ATV rides MUCH better than a tractor
In a tractor you could probably do 5 to 6mph tops.
Why do you think I use the ATV?
/ CHAIN DRAG HARROW #36
What would (or wouldn't) be the benefit of going with a simple chain drag harrow vs. the Marten's harrow for my application. I would only be using it to maintain my pastures primarily to keep them healthy, promote growth and speading horse manure. I like the Marten's because of the 3 pt. hitch, 7.5 ft. model and the price point. On the other hand using the Tractor Supply version as an example only, it is cheaper but in order to get similar model from another manufact. with a 3 pt. frame your looking at another 500 bucks. Will the Marten's do what I need or do I need to specifically go with the chain drag type? The lift capability of the Marten's at 650 bucks is really got me stumped.
This: 3 Point
vs.
This: Tractor Supply Company - DRAG HARROW
/ CHAIN DRAG HARROW #38
I brought my Martens spike-tooth harrow home on Thursday, but won't try it out until Monday.
I will say this: Mr. Martens was extremely nice and professional, and the appearance of the unit is top-notch. I told Mr. Martens that I would be preparing some pecan bottoms for clover seeding with the unit, and he threw in a few extra teeth in case I hit an unforgiving stump at a bad angle. I am rough on equipment some times.
/ CHAIN DRAG HARROW #39
I must be turning into a real tractor guy :D I'm a newbie, but have something to contribute.
I seeded about a half acre of fescue this past week. My neighbor was kind enough to lend me his disc harrow to break up the ground, then, after seeding, I borrowed this chain harrow to cover the seed. Worked beautifully.
Here's the finished product.
/ CHAIN DRAG HARROW #40
Looking forward to hearing about it. One of my concerns with the Martens (which may indeed be totally unfounded) is that since I will be using it for 90% field/pasture manicuring and breaking up and spreading horse manure, are the teeth too far apart? Will it require me to make several passes over the same peice of property in order to sufficiently spread the material? Again this may not be true but its hard to tell from the pictures on the Martens webiste.
2025 JMR Stump Bucket Skid Steer Attachment (A66734)
2025 JMR Stump...
XTREME XR1147 TELESCOPIC FORKLIFT (A65056)
XTREME XR1147...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
PORTA POTTY (A68842)
2024 CATERPILLAR 239D3 SKID STEER (A65056)
2024 CATERPILLAR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
