Chain basket for JD 3032E
   / Chain basket for JD 3032E
JDfire, let's just say that certified welding inspectors are not welcome around my shop. :)
   / Chain basket for JD 3032E #12
Looks great - inspirational even:thumbsup:
Did you use brake to bend the expanded metal?
No, bending a single piece would have made more sense, but unfortunately I don't own a brake. I did it the hard way by carefully cutting and matching up four sides and a bottom piece, and welding them along the inside using tiny 1/16" 6013 rods and low heat. With a little judicious grinding and cleanup it came out looking almost like it was all one piece bent on a brake. After putting 3/4" angle around the top and bottom and adding a couple of pieces of 1-1/2" x 3/16" strap on the back for mounting, the resulting "box" was very stiff and solid. It's amazing how much chain a little 4x4x8" box will hold. I have three lengths of 5/16" chain in it right now and it's only about 2/3 full. It's turned out to be a very handy addition, no need to walk back to the shop for chains anymore, it's always right there when I need it.
   / Chain basket for JD 3032E #14
Wow! I am even more impressed, I would have never guessed the expanded metal was not all one piece. A lot of people don't think you can weld little thin metal with stick, but you have sure showed them! I have used more 1/16 rod, either 6013 or 7014 (looking for low penetration, high deposition) than all other sizes/types. I usually find myself trying to repair some little thin broken piece of junk. I am in the process of learning gas welding, getting better:)
James K0UA
John Deere 4240 (A53317)
John Deere 4240...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
UNUSED WOLVERINE MPF-11 2500G 30" PALLET FORKS (A57193)
UNUSED WOLVERINE...
