Chain and Binder - general tie down question
   / Chain and Binder - general tie down question #21
No brainer. G70.
I run 5/16 and think it is a good weight. Pretty easy to handle. You can run 3/8 if you feel strongly about it, but I think it's totally unnecessary. that G70 chain is very, very, very tough stuff. I had them cut it at TSC and it broke their chain cutter thingy.
As far as 4 chains vs. 2, I dunno. Honesly, the tie-downs are probably more prone to breaking than your chain. I use 2 chains looping through 4 tie downs and 4 tie points on the tractor and feel pretty good about that arrangement. In a wreck, I figure the entire hitch assembly is going to tear out of the back of my truck before the tractor flies off the trailer. Just a guess, though. Don't want to find out.
I run a 4WD Expedition (regular length) with all the tow-trimming, very similar to yours. I have a Tekonsha P3 controller. I have a heavier trailer (10k) and have hauled within 100# of the GCWR without any trouble at all. With your 7k trailer, you'll always be in the sweet spot of that rig. Very good pulling truck.
Just a "heads up" on a good price, I have discovered the local HomeDepot carries a 5/16" X 20' Grade 70 "binder chain" for about $40.00. Hard to beat that price if shipping is involved :D
Rebel, I actually saw the 5/16" chains you were talking about at Home Depot and Lowes over the weekend. I think they were either $32 or $37 (plus tax) for 20 footers with hooks installed (grade 70) made up in a carry bag. Not a bad deal at all considering the weight and shipping costs.
If I can find the chain locally I might use the grade 70 5/16" on the front corners and the 3/8 grade 70 on the back because of the hills I have to maneuver through when taking it for service. The one 7 mile 6% grade hill (freeway) carries some pretty heavy traffic all in a hurry to get nowhere. I've had to do some pretty tricky stuff just driving on it let alone towing 5 to 7000 of tractor and trailer down one way and up on the way home. Thanks !!
No brainer. G70.
Thanks Keith, I feel pretty good with the Expedition EL. I've towed the rental tractor TLB from Home Depot before (which I think is heavier than my B3200 will be with TLB) and didn't have any problem with power but the setup they have isn't very good, way to much weight on the hitch. There is no room to balance the load because of the size of the trailer they have it on. I have to check, it might be a 10K trailer, it sure is a brut for their setup.
   / Chain and Binder - general tie down question #24
After reading here about the chain at Home Depot I made it a point to look at the chain at Lowe's today when I was there. they had a 20' pc of grade 70 3/8 chain in a bag for $35.00. it was the only thing in the store rated G70, everything else was G40, all the chain, hooks and accessories.
I'm almost positive it was 3/8", and had G70 hooks as well, I'll check again next time I'm there.
JB.
   / Chain and Binder - general tie down question #25
JB.
Guess I'm wrong, just checked their web site, this is all I can find.
http://www.lowes.com/lowes/lkn?acti...44&Ne=4294967294&Ntk=i_products&Ntt=tow+chain
That's what I thought, both HD and Lowes here carry the same 20' lengths with hooks, grade 70 5/16"
   / Chain and Binder - general tie down question #27
It's true there is strain for and aft but there is more strain on the rear due to braking and a potential for the highest stress during an emergency stopping situation. As opposed to the strain on the front due to hill climbing or accelerating, although if you have a powerful tow vehicle and a heavy foot I guess you could put some serious strain on those front chains as well.
I will also put my higher rated hardware on the rear, (2 new G70 binders and chains) I have some old high quality 3/8 chain that may even be better than G70 but since it's not marked you have to assume it's the lower grade, I put that on the front with the 2 china binders I got with the tractor, they're still rated for 5400 WWL so well within my needed capacity.
JB.
   / Chain and Binder - general tie down question #28
...strain will shift from the front to the back as you go up hill and down hill.
Seems that setting the parking brake, leaving the HST in gear, and putting the FEL/BH buckets on the deck would mitigate most of the "casual" roll a tractor would experience, correct?
I wouldn't load a car on a trailer, leave it in Neutral with no brake on and rely ONLY on the straps to keep it in place...belt and suspenders, you know...
   / Chain and Binder - general tie down question #29
Harbor Freight has the chain and binder
- Harbor Freight Tools - Quality Tools at the Lowest Prices
3/8" x 14 Ft. Grade 43 Trucker's Chain $27.00
9200 Lb. Ratcheting Load Binder $24.99
Shipping is about $12.
For a little over $200 you can securley tie all 4 corners down. I would tie all 4 corners as opposed to two. Tailers bounce and so will your load. Also, tieing all 4 corners will also help to keep the unit from tipping over.
I agree witha previous post that if you were to put 4000 lbs worth of load on the axles, you would break you tractor. However, I would be more concerned with using a weaker chain still. If you would get a little bit of slack and then it would tighen up, there would be more stress put on the chain then when it is just binded.
THis might cause an arguement, but chains do get weak with time/use/abuse. I had a chain (I don't know it's weight rating), I pulled stumps with it all the time with my truck. Well, one day it snapped, luckily missed my truck as it flew buy. :eek: Man those things can spring like a rubber band.:confused: Anyway, I put a new hook on the chain and tried to pull that stump out again, it broke even easier the second time.
Hopefully with a stead load and no yanking on the chain with high pressure you would never see that. I agree with another poster that asked how much is your equipment worth? SPend the extra $50 to save yourself thousands and give you piece of mine.
I think the general opinion on here is know what you want, and go one bigger. I know that statement was geared toward tractors, but really can apply to about anything.
I know I used 4 10,000 straps, while they worked well, I will be upgrading to chains when I get my trailer. Most likely the same I posted links for above.
   / Chain and Binder - general tie down question #30
Why put binders on the rear? Why not put the chains on, then move the tractor forward a bit to snug it up, then use binders on the front to hold it there? Seems like an easier and maybe more reliable approach.
Ken
207276 (A52708)
207276 (A52708)
Nissan Forklift (A55973)
Nissan Forklift...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
207271 (A52708)
207271 (A52708)
