CH20 Ignition switch problem ?
   / CH20 Ignition switch problem ? #1
39President
My CK 20 HST has 360 hours on it. Noticed after 100 or so hours, when I turned the key from glo plug to start, there was a slight pause before the starter would engage. The colder the weather, the longer the pause between the key turned to "start" and the starter engaging. Today the pause was the longest yet. All connections are clean and tight. After the first start-up, the pause is not there. Only comes back when the tractor has not been used for a week or more. Any thoughts?
   / CH20 Ignition switch problem ? #2
Do you hear the solenoid click before the starter spins?
Thats the pause. Turn the key to start position, long pause then the solenoid click and starter spins fine, engine fires right up.
   / CH20 Ignition switch problem ? #4
I'd check all the battery cable connections first. At battery, ground to frame, and positive to starter. I've seen where these connections have become corroded and the power draw when starting causes a very slight ark that actually allows for a better connection. If all good, then the switch could be the problem. Many posts here about the switches. Members have shot in WD-40, fluid film, and other lubicants. The factory grease seems to attract dirt, gets hard, and then the switch connections are lost or intermittent.
   / CH20 Ignition switch problem ? #5
If I'm reading this correctly, there is a pause between the time the switch is turned to "on" and the time the stop solenoid makes its distinctive clack sound. Furthermore, the delay is longer when cold, there is no delay starting a warm engine, and the engine always cranks.
If this is correct, I suspect the ignition switch grease is thick and/or dirty, causing a poor connection (in the switch). Recommend the easy thing first: squirt some WD40 or Fluid Film (which is better) in the keyhole. If this fixes the problem you'll know it's the switch. You may need to rebuild or replace it eventually, or maybe the quick fix will last for years.
I was leaning towards the ing. switch, sprayed some electronic switch cleaner in there, no effect, I'll try the WD40. Having a snow storm right now , eastern New York. Thanks for the info/help.
   / CH20 Ignition switch problem ? #7
You can also remove the switch, take it apart, and clean up all the contact points. It's not difficult. Mine is a ck30 so I assume they are similar.
   / CH20 Ignition switch problem ? #8
Seems to be a frequent switch problem. The lubricant is dry and caked up.
The inner contacts are spring loaded for good contact but also lubed to prevent wear.
WD40 and a good agitation (on/off/on/off) will cure that in most cases.
I'd not open the switch but do spray on a yearly basis.
I once met the WD factory rep and he assured me that WD40 is non corrosive and OK to use on all electronic components. We consequently used it on lots of expensive aircraft electronics.
   / CH20 Ignition switch problem ? #9
From what I've been reading, this seems to be a constantly recurring problem.
After I left my aviation maintenance career, I took on summer contract work for a busy yacht charter company. Working on sail & power boats that spent their entire lives in a harsh marine environment. In 9 years, I think I replaced one "ignition" switch.
Many marine diesel switches function in the same way these problematic Kioti switches do & it'd be a simple job to change them out. For about $30.00, it seems like we could save a lot of unnecessary grief.
It would be better if the manufacturer would step up & make a better switch, but it doesn't look like they are that interested.
My new DS4510 arrives on Saturday. (three more sleeps!) One of the first things I'm gonna do is look into replacing that switch!
I hope someone will chime in, if this issue has been addressed with the newer tractors. Or if anyone has tried this already. (Someone MUST have)
P.S. I posted previously that the model I bought was a DK45SE. Wrong... It seems I wrote down the wrong model number in my notes.
The DS has fewer bells & whistles, but as a true bush mechanic, I'm OK with that!
I'll formally join the "club" when I get the tractor home on Saturday.
Cheers. Dan
   / CH20 Ignition switch problem ? #10
The ignition switch has been a problem dating back at least to 2006 (when I got mine). After a few months my switch started acting up. I cleaned it with brake cleaner. Let it dry and then added some fluid film, both in the hole and on the key (love that stuff). It's been working ever since. However, it does have a dead spot. If I turn the key too far it won't engage. I have to turn it just far enough. I've done it so much that now it is second nature. I would have thought by now that Kioti would've fixed this.
UNUSED RAYTREE RMSC78 78" HYD SOIL CONDITIONER (A57193)
UNUSED RAYTREE...
Misc Gas Equipment (A56469)
Misc Gas Equipment...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2020 Nissan Altima Sedan (A55853)
2020 Nissan Altima...
(3) 20' CHAINS, (2) RATCHET BINDERS (A57192)
(3) 20' CHAINS...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
