5) MY vote is, to give it to another TBN member to use, to see if the mower keeps on breaking down!
Somehow, I'm thinking with a quick check over, it won't.
SR
Not sure I'd care to inflict this evil device on any of our TBN members.
Before I use ANY equipment (from push mowers to airplanes), I do a "preflight" to make sure that all fluids and lubricant levels are correct, there's fuel in the tank, tire pressures are correct, nothing is hanging, bent, broken, leaking or smoking, all the various clips, hatches, safeties are secure, and so forth.
I've been told that real men don't read instructions, but I do, and I'm not ashamed to refer to them frequently. I'm also fanatical about following the maintenance schedules and fixing things right - no duct tape or baling wire allowed.
Most of what has gone wrong with this mower stems from poor design, zero pre-delivery inspection (which I have remedied), bad welds from the factory, things vibrating apart, just generally no quality control at ANY point from engineering to assembly to delivery.
I have more hours on my Kubota, which works a LOT harder than this, and has had far fewer problems. All the Husqvarna has to do is cut grass. The Kubota has an FEL, bush hog, belly mower, grade box, pallet forks and it gets used for all kinds of things and just keeps going, all that falls off is a flasher lens from time to time and they are $1.29 at Tractor Supply.
Admittedly, the Kubota cost more than ten times as much as the Husqvarna, but I also have a 30 year old Murray push mower (remember them?) which keeps soldiering along, runs just fine, and cost less than $100 new. I also have two motorcycles which I have owned for fifty years (!) and they also are just fine.
All of these are stored inside so they are not out in the weather, and nobody else uses them.
Like you, I've seen plenty of vehicles where the owner was the biggest problem but in this case I plead not guilty. This mower was evidently assembled on a Friday before a LONG holiday weekend, and the QC crew was very hung over when it got to them the next work day.
Best Regards,
Mike/Florida
