Century/Lincoln Connection: Does It Matter?
/ Century/Lincoln Connection: Does It Matter?
Bobodu,
I still can't get over that cart you have the welder on. I'll call it elegant... everything it needs to be and nothing more. It's great.
/ Century/Lincoln Connection: Does It Matter? #22
Bill, right, the 170 is 220 volts; both are built on the same platform.
You say that the power supply gets hot and the welding power drops off. I am surprised that the overheat sensor did not trip. Maybe what is getting hot is not in contact with the overheat sensor. Someone mentioned that some transformers are wound with aluminum wire, that could be a problem in it self.
I take it that the fan is in good working order and that the air vents are all wide open, and air is not leaking from gaps in the cover?]
Transit,I took my welder apart over the weekend and disconected and reconected every connection I could find. I did find a slightly loose conection on a ground lug. I put it back together and it welds perfect! I don'tknow what I did to fix it but I glad it did . It saved me about $1000. Thanks for giving me the idea.
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
378721 (A54865)
378721 (A54865)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
