Century 3045 stop relay
/ Century 3045 stop relay #1
city boy
St. Louis county Missouri
2001 Century 3045. 1939 9N ford
Anyone know where I can find a "stop solenoid relay" for my 2001 Century 3045 tractor? I have been looking on the internet with no luck. What other brand of tractor should I look for that might match the Century 3045? The relay controls the stop solenoid on the injection pump. I have found out that the 3045 uses the Yanmar engine wih direct injection system. I guess that makes it different from other models..The relay is stamped OMRON KG8JR-1A2T
Thanks
/ Century 3045 stop relay #2
Bills Tractor carries Branson parts and takes internet orders.
I had mine stop working recently. Turned out to be dirty electrical connections. Before spending money, make sure ALL electrical connections, from fuse block on, are clean and working.
Okay, I agree but what Branson model do I use that would be the same as my Century?
I found that the Branson model would be a model 4520. Does that sound right?
/ Century 3045 stop relay #5
pXVY7K5wvb6W5H05SLBOUki3vJy0mhi-rQaqKQc7cZzK8cY0XguNt0WB_FXgBbtUkaTak6BzB5QeBRjGBo1VBGe1uolKXVRvkpM=w1024
/ Century 3045 stop relay #6
The Century 3045 is the same tractor as a 4520 Branson. With a Yanmar 4tne88-erkb engine you local Branson dealer will be able to order parts foa all Century tractors
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
2012 Ram 1500 Crew Cab Pickup Truck (A64556)
2012 Ram 1500 Crew...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
