century 2045 steering
/ century 2045 steering #1
sizemore
century 2045
I have a Century 2045 4wd tractor. The power steering doesn't respond the way it should. Cant fing power steering pump to check fluid. Any help would be appreciated.
/ century 2045 steering #2
Look under the operator platform on the left side in front of the fuel tank. There is a bottle there that is the power steering hydraulic fluid reservoir. If you lift the rubber pad up there is a hole cut in the operator deck to aid in adding fluid.
A common problem on these tractors is the factory reservoir bottle cracking and leaking. There are 3 options to fix this 1) replace the plastic bottle with a bottle made of the same material 2) replace the with a metal bottle 3) plumb the steering hydraulics into the main tractor reservoir.
/ century 2045 steering #3
There is also a serviceable filter in that reservoir (if it is like mine). If your tank has deteriorated I definitely recommend getting the metal tank.
