Center Nut on the 425
/ Center Nut on the 425 #1
pajoube
Montana (Near Bozeman)
Former Owner PowerTrac 425 (September 2003)
I have read over the past months that a number of you PT owners bought a wrench to tighten the center pivot nut.
Well I thought this over and ended up buying a 1 13/16 wrench on EBay about 6 months ago, put it aside and never gave it much more thought.
Today was a nice day out so I rummaged around and found it and tightened the center nut.
Boy, was I ever surprised at how lose it was. I did at least 10 half turns until it was tight.
Sure glad I bought than wrench. By the way, I paid $9.99 for the wrench and $12.00 for shipping.
PJ
/ Center Nut on the 425 #2
When I took the training class at Power Trac, they told me to tighten it every 8 hours of use, and grease at the same time. I found that it has moved less as time goes on, but the first few times I got some movement.
/ Center Nut on the 425 #3
We have a local "Surplus City" store that has the 1 13/16 wrench in stock. Just picked one up for $17.32 including the usual donation to the governor.....now the biggest wrench I own! If anyone is interested in obtaining one feel free to PM me and I'll see what it will cost to ship it to you....not trying to make any $$ here just trying to get this wrench to those that need one at a reasonable price. I was waiting to see what EBay would have but seems I'm slow at pulling the trigger at a decent price. It's a combination "drop forged" wrench made by "Thorsen"..although sticker says it's a Mills Fleet Farm? Of course, it's made in Taiwan.
/ Center Nut on the 425 #4
Opps ..... will do again this weekend. So once a year don't work....
/ Center Nut on the 425 #5
I checked with my local tool store and a 1 13/16 wrench was pretty pricey and not carried in the cheep brands. There is available (under $20, I don't remember exactly) a box-end wrench in the cheep line that is 46mm, which I was assured will work exactly. They've ordered it and I'll verify their promise once I receive it.
Phil
/ Center Nut on the 425 #6
Phil
I have seen them at Northern for around $20. I don't think you are going to be able to break even a cheap wrench of this size.
/ Center Nut on the 425 #7
I think the one I got what would be classified in the "cheap" quality category and it's a pretty heavy/thick wrench. Used it for the first time this week on that nut and it went around almost a full turn after apprx 250 hours. Looks like it will be part of my pre-start check up from now on.
/ Center Nut on the 425 #8
I think many people are missing an important maintenance item by not tightening this every eight hours of use. When it has slop there is a lot more wear in the coupling. When I tighten it I rarely get an eigth of a turn. Probably not an eigth of a turn in the past year. If you got a full turn in a year, then that is more wear than I got in 5 years. Keep this thing tight. You don't want to have to replace that joint. Somebody correct me if I am wrong on this.
/ Center Nut on the 425 #9
Hi all,does anybody know if the center nut on the 422 is the same size as the 425?
/ Center Nut on the 425 #10
BobRip has a 422, so apparently they are...
/ Center Nut on the 425 #11
The 46mm I mentioned works great but it ended up being almost $30 out the door. Finally got it last week.
I got almost a full turn easily on my 422 nut.
Phil
/ Center Nut on the 425 #13
It's a 1 and 13/16 on my 1430 as well. Initially i thought terry had said a 1 and 15/16 wrench but when i picked that wrench up it was too big. I then got the 1 and 13/16 wrench from Boston Industrial Tools part #19563 for around $12.50 or so phone # is 1-781-335-8829
/ Center Nut on the 425 #14
Thanks for that, just ordered one.
Jack
/ Center Nut on the 425 #15
Thanks from me too,
just ordered one also.
I have been putting it off for to long.
Abe
/ Center Nut on the 425 #16
Received my order. Man, now that's a wrench! Much larger than I was anticipating. Got about a turn and a half on the nut.
Jack
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
1999 Wallace Trailers 42ft Tri Axle Low Boy Equipment Trailer (A59230)
1999 Wallace...
2005 Nissan Frontier Crew Cab Pickup Truck (A59230)
2005 Nissan...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
