Cement or concrete
/ Cement or concrete #1
Trainer
Arkansas
Massey-Ferguson 220-4
Going to pour a slab for a garage. I have heard about the cememt/concrete with fiberglass in it. Was told by some that I would not need rebar, only the fiberglass/cement mix. Someone please give me some feedback on the use of the fiberglass/cement mix.
Will I need rebar and wire in the slab?
/ Cement or concrete #2
The last time I poured cement the guy driving the truck offered the opinion that when they use fibre glass instead of steel in bridges he will stop using steel also. Until then he uses both.
When I poured my garage floor they forgot the glass but I did have all the steel in. I was preoccupied and did not notice until we were finishing. :mad:
/ Cement or concrete #3
All I have heard is you can do that with metal mixed into the cement. The owner of the local Cement company owner here did his new house this way, I guess to prove the point. I can't remmember what its called but I know it was like a very fine steel shred.
Every one else I know still uses rebar with fiber ( any kind) in the slab
/ Cement or concrete #5
To answer your question on "cement or concrete" I can say that you are pouring concrete. An ingredient of the concrete is cement. You don't pour cement as cement is a powder.
I like steel in the concrete and the fibers are not a substitute. I also like to cut joints into the green concrete to control the cracks.
/ Cement or concrete #6
I have poured well over a thousand yards of concrete at my place. I personally like the fibercrete along with regular rebar and 6 gauge steel matting. That seems to be the best combination for keeping the only cracks that appear to be hairline cracks. With only steel some of the cracks have gotten a little separation. Not enough to be able to fill with anything nor have any of the slabs moved vertically, but the cracks seem to be slightly larger than the concrete poured with the fiber in it. One area on a porch was poured with only fiber and no steel. I was not impressed and it was replaced.
I asked why they use fiber and not something akin to steel wool. I was told that anything like steel wool for fiber would be completely rusted and gone within a couple of years. So, based on the huge amount I have spent on concrete, and having had some extremely heavy traffic on my driveway, I'd say without a doubt to go with the fibercrete along with regular heavy gauge matting and rebar.
Thanks for the replies.
/ Cement or concrete #9
Concrete is a mixture of Portland Cement, gravel and sand. You can add other ingrediants to the mixture for strenghth and drying time, but the basic ingrediants are always the same.
Portland Cement is named after the place in England where it was invented.
There are two things that you can guarantee with concrete, it will get hard and it will crack.
To minimize cracking, you can add fiberglass to it, but this does nothing to increase it's strength.
Rebar does this. Bigger rebar and more of it will give you more strength. A higher ratio of Portland Cement will also increase the strength of the concrete. Less water in the mixture will give you stronger concrete then a wet mixture. The less water the better. Slow dying time will add strength to concrete. If it's really hot out, the concrete will cure faster then is should, and you will lose strength and increase the amount of cracks.
Adding fiberglass will help to a certain degree, but doing this instead of using rebar is not something that I would do for anything that I owned.
Eddie
/ Cement or concrete #10
fiberglass is often used on slury pump projects, were forming rigid rebar would be especially complex and expensive. were as you simply pump the concrete inplace and it already has its reinforcement included.
Rebar in bridges is load carrying part of the structure. Simply adding mesh to flat work to prevent cracking due to thermal movement has little to do with adding steel reinforcement to carry load.
/ Cement or concrete #11
For a garage slab I don't think I would go with the fiber glass. When floating it rises and it will show on the finished surface. It's not a big deal but, I like a smooth polished surface.
/ Cement or concrete #12
to deal with this you usually just flame the surface with a weedburner within a few days. melts all the fiberglass twigs sticking up and youll never know they where there.
/ Cement or concrete #13
Exactly. And, my concrete contractor said that the fibers would actually help prevent spalling as well.
/ Cement or concrete #14
I noticed on a bag of cement that it said "not for concrete". Can anyone explain what the difference is between cement for concrete and that for brick laying? I want to build a small (1m sq) slab and was wondering if I could use the same cement for slab and brick laying.
Weedpharma
/ Cement or concrete #15
J_J said:
Here is a product that was originally created by University of Mich.
Helix
Excerpt from about us:
Helix are toothpick-sized, pieces of twisted wire with a triangular cross section, developed at the University of Michigan in 1997 then licensed and commercialized by Polytorx LLC. With its screw-like shape, Helix works by locking into concrete like a corkscrew in a cork and even very low dosages of Helix result in dramatic performance improvements for all uses of concrete. Helix is now used in thousands of applications and sold in 10 countries.
Kurt
/ Cement or concrete #16
I had a 24 x 28 slab poured in 03 for my garage. No rebar or wire mesh only fiberglass mixed with concrete. No cracks after 5 years and it is driven on everyday.:)
/ Cement or concrete #17
My 24X36 garage floor is this fiberglass/concrete mix. No rebar.
No cracks except for the ones that are suppose to be there.
The 'fuzzy look' went away within a few days use.
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2012 Chevrolet Silverado 1500 Pickup Truck (A61573)
2012 Chevrolet...
2012 John Deere 1770NT CCS Planter (A63109)
2012 John Deere...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
