Cement mixer attachment
/ Cement mixer attachment #1
egb6550
San Jose, Calif
Anyone have experience with the cement mixer? I'm thinking about using it to make paths/sidewalks. Is it easy to use worth the investment? I have the 422.
/ Cement mixer attachment #2
I would like to know too. I just got done mixing 320 lbs of cement, and i have another 1000 lbs still in bags in my garage. Shovel and wheelbarrow just doesn't cut it?
I am wondering if the cement mixer barrel is made out 3/16"+ steel like every other attachment. Kind of looks that way in the pictures. Just a bit overbuilt, if so.
/ Cement mixer attachment #3
The barrel is made out of some type of plastic material very tough. You can put two 80 lb bags of premix and mix it in about 30 seconds drive to where you would like it and dump.
The only problem I have is the speed it turns you have to run the tractor just above idle. If you don't it turns so fast it acts as a centrifuge. I have mixed tons with mine takes the work out of it. It will not mix mortar.
sg
/ Cement mixer attachment #4
I also have used mine to mix soils which is very efffective.
PJ
Kubota B21 TLB (A60462)
Kubota B21 TLB...
207271 (A52708)
207271 (A52708)
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
