ceiling fan
   / ceiling fan #1
tglass
Platinum Member
3320 w/cab
Is there an easy way to clean a ceiling fan without dropping all the dust and whatever all over everything underneath? Yes this is embarassing to ask, and no, my place is not filthy, but when someone has just washed the sheets and bed spread...well someone is going to catch more than the dust and clean the fan blades. Guess who is on the wrong end of the fan?
   / ceiling fan #2
Vacuum sucking while dusting.or wet cleaning rag w/small trash can below as you wipe.
   / ceiling fan #3
I use a damp cloth and wipe the blades with it. If I'm careful it will all stay on the cloth. You could hold some newspaper or cardboard underneath if you are afraid some will drop. Using a wood stove nearby seems to coat our fan with dust :mad: so the blades get cleaned several times a year.
   / ceiling fan #5
they have an attachment that fits on the end of the vaccum hose
   / ceiling fan #8
you could remove each of the 3 screws holding on the 5 blades then take them outside hose-um-off:D although you did mention " easy way" so I'd go for the shopvac and the fan cleaner attachment,:thumbsup:
   / ceiling fan #9
I just run mine on 'High' from time to time.......
   / ceiling fan #10
you had to make me look at mine. they need cleaned. :laughing:
I use a damp paper towel.
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
John Deere 1770 Conservation 16 Row Planter (A50775)
John Deere 1770...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
KNAPHEIDE SERVICE TRUCK BODY (A51406)
KNAPHEIDE SERVICE...
2020 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (A50775)
2020 Kubota...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
