Ccw pto clutch
   / Ccw pto clutch #1
Goatfeathers
Does anyone know where I can get a override clutch for a counterclockwise rotating pto?
   / Ccw pto clutch #3
Open it up and see if you can turn the fingers around...
   / Ccw pto clutch
It just "overrides". No drive.
   / Ccw pto clutch
I tried that ,no luck, made one way.
   / Ccw pto clutch #6
Like aczlan said, if you put the clutch on the implement side, it will be operating correctly in a counter-clockwise direction. If it is ratcheting on the implement side, then you either have a clockwise rotating PTO, or a reverse-rotation clutch already. Put it on the tractor and you should be good to go. :thumbsup:
CFG Industrial QK18R (A50121)
CFG Industrial...
1986 John Deere 6359D (A50121)
1986 John Deere...
CAT Skid Steer (A50322)
CAT Skid Steer...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
