Toplink CCM Hydraulic Toplinks have Arrived!!
   / CCM Hydraulic Toplinks have Arrived!! #11
The CCM guy I spoke with suggested their medium HTL might work for me. He said it's 18-26". Seems a bit long to me??
   / CCM Hydraulic Toplinks have Arrived!! #12
Opps, sorry. I measured the side arm. I thought you were looking for the tilt part, not the top link. I will measure the top link for you.
   / CCM Hydraulic Toplinks have Arrived!! #13
Slippy, you're going above and beyond. I really appreciate the effort. Thanks
   / CCM Hydraulic Toplinks have Arrived!! #14
CCM's finest ready for summer!
   / CCM Hydraulic Toplinks have Arrived!! #15
Top link on my TC40DAss is about 20 1/4" fully retracted and 30 1/4" fully extended. Fully extended is at a real angle. I don't really know what you would use at that angle, but those are the numbers. Good luck.
We have the toplinks in Johnson City, TN and we are rolling!
Thanks,
Mark Carter
   / CCM Hydraulic Toplinks have Arrived!! #17
I'll chime in on this, to recognize good customer service. I just received a call from C & C regarding this, as I had asked to be put on a list notifying me when these top links were available. I placed my order and hope to see it soon.
Thanks Mark for following through, after what seemed like forever. A'int that always the way when you want something, and its not available when you want it!!!!!!!
WALT
   / CCM Hydraulic Toplinks have Arrived!! #18
Anybody got the diminsions for a CK30 toplink? My rig isn't real handy right now.
   / CCM Hydraulic Toplinks have Arrived!! #19
Something to think about when ordering -
I put "Pat's" easy change system on my L3400, and because of the resulting extended length of the bottom arms, I had to replace my toplink with a longer one than the original (I believe my current "longer" toplink has to extend to about 34" for a couple of my implements... the original would not go anywhere near this length). Take this into consideration if you plan to use a "Pat's" system, because you may need a hydraulic toplink that will extend further than the toplink that came with your tractor.
   / CCM Hydraulic Toplinks have Arrived!! #20
Just got my cat2 HTL from CCM and had a question about the hydraulic hoses. I'm thinking of going with the 1/4 inch hoses as some of you have suggested in previous post for better control of the toplink, Is this still the recommendation using the cat2 toplink or should i use a larger size hose.
I'm a new member, so i would like to say thanks for sharing your knowledge :D
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
BELSHE DT-235 (A55745)
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
