cc 2550 or jd x324
   / cc 2550 or jd x324 #11
Petertucky,
IMO, due to less complexity from not having 4 wheel steering, and having a fully servicable transmission the CC is a sure bet. I know that the Deere's transmission may be plenty for just what you are planning to do but I know that with my luck, something would go wrong 1 day after the warranty period. At least with the CC, it is fully serviceable and since it is so much overkill, much less likely to have a problem. Trying to make a machine last 12 years, I would lean towards a JD x320 rather than the x324 because of less complicated moving parts or certainly the CC. Also, I've read that having a horizontally shafted engine is better than a vertically shafted engine. Not so sure as for the reasoning but just something that I have come across on the internet.
As a side note, I have 5.5 hours on my GT2544 after an afternoon of pulling out some more forsynthias and I cleaned her up real nice with compressed air and some spray and shine. I noted the locations of the grease points various lube items and they are really accessible and I went under the machine (my deck is off) and looked up and everything looks to be easy to work on for me.
-No problems so far except for changing out the plastic oil drain valve to a Fumoto and I will be replacing the transmission hydrostatic oil filter at 10 hours as indicated in my manual and topping off the transmission with any fluid lost during the procedure.
   / cc 2550 or jd x324 #12
Petertucky said:
I am new here. Live in SW IN, & mow 2 1/2 acres. I am going to buy either the cc 2550 or jd x324. As I decide, I have questions and comments.
How hard is the deck on the cc to remove and attach? I think I will have to remove the deck to get it on the trailer home and for future maintenance. The belt from the engine to the deck looked like it might have some twists in it. I think the JD 48 inch deck will fit on my 54" trailer with the Chute up, but the 50 inch cc deck (actually 54 inches wide with chute up) mower won't fit on the trailer.
Does the blade on the non-discharge side of the cc deck come close to the edge of the deck to aid in tight turning mowing arount trees, etc.? The Jd blade appears to come very close to the edge of the deck. If I buy the cc I will be giving up the 4ws, and I don't want to regret giving that up. JD calls their deck edge extra, but I hope that the cc deck has blades near the edge of the deck too.
My heart is actually with the Cub, as evidenced by this request on this thread and not on the JD thread.
Finally, is the cc reliable and durable? I want 10-15 years out of it, rather than the 5-7 out of my yard machine of years past, or my current Troy bilt.
Thanks
The CC 2500 series are Garden tractors a step up the ladder from Lawn tractors.
JD 300 series are lawn tractors.
   / cc 2550 or jd x324 #13
Thanks
Almost anything is an improvement over one of these or any other box store unit.
   / cc 2550 or jd x324 #15
I consider even JD's X500's to be lawn tractors too. They are more or less what a Cub 1500 is just souped up with more options, like 4 wheel steering that makes them $3000 more expensive than a Cub 1500. But they have the same vertical engine, belt drive, aluminum transaxle setup. -Fordlords-
   / cc 2550 or jd x324 #16
jay25rs said:
Petertucky,
I lost 3 quarts of tranny fluid when I changed the filter on my 2554 the other day. That was half of the 6 quarts it holds.
Put a container large enough to hold at least 3 quarts under the filter before you take it off . That way you should limit fluid loss to way less than a quart.:cool:
   / cc 2550 or jd x324 #17
Petertucky said:
Wow chip. I think I measured the 2550 deck to be 54 inches. If your shed door is 55, that is tough. I was dreading the 56 inch opening on my shed. Thanks for letting me know it can be done.
Overall, I think the John Deere would be adequate for what I will do. Haul some firewood in winter, mow the grass, light duty stuff. No real plans for snowblower (in Southern Indiana we don't get big snows that last long), or tiller attachment. I like the uncut radius of the 4ws too.
I really appreciate all the help. Tomorrow is when I buy, and I still haven't made up my mind.
One last question for thought. Which will last longer? My kids will be entering college in a few years. This new mower must last at least 12 years. My first, basic, bottom feeder MTD Yard machine lasted 7 years with me. (Actually, my brother still mows with it and it is a 94.) I bought a Troy Bilt in 2002 for about $1800, and frankly it is not close to being double the machine. The twin intek is smoother, but that is about it. It has been disappointing, but now my brother will get it.
So here I am. Probably willing to buy either machine. Which will be more durable and more trouble free?
This ought to open up a can of worms.
I sure wouldn't pay more for the JD than The CC.
   / cc 2550 or jd x324 #18
ChipSmith said:
1* Cub lists the weight of all their tractors and you can see how the weight jumps up dramatically going from the LT series to the GT series. If you have any hills or rough terrain, the weight will definitely be a bonus.
2*I was talking to my Cub Dealer yesterday. He told me that the same day that he delivered mine, he also delivered another GT2550 to another customer who had just bought a JD x320. When we got there the JD dealer was there picking up the x320. Apparently the JD couldn't make it up the customer's hills (it would just spin tires). The JD dealer was embarrassed, especially when the GT2550 climbed the hills with no problems.
1* Poor traction on a hill was one of the main flustrations I had with my LT.That problem was solved when I replaced it with A CC GT 2554 Garden tractor.
2*This sumes it all up.;)
   / cc 2550 or jd x324 #19
When I go to antique/classic tractor shows, I enjoy watching lawn and garden tractor pulling competitions. They really show what prevails as far as getting the best traction.
Of course everyone in these competitions uses AG tires. Some even chain the AG tires. Provided everything on the tractor works right, two of the best factors of winning (aside from driver experience and technique) are rear wheel diameter, and rear end weight. I've seen little 8 and 10 HP Speedex's that had wheels that come up to my waist pull the sled like a sack of feathers. The large diameter wheels have a big contact patch that gives them a good grip. Add wheel weights and a 300+ pound driver to a JD 110 or Cub Cadet original and you get just about the same results- a smaller contact patch but a lot more weight on it. To do serious work or climb inclines with a small tractor, weight and grippy tires truly help them.
-Fordlords-
   / cc 2550 or jd x324 #20
turbojerk said:
If you're mowing 2.5 acres, you may want to consider stepping up to the GT2554 instead, unless you have got time to burn.
I mow 2.5 acres myself and it takes pretty much 2 hours easily with my GT2554.
I did have a few issues with my Cub at first, but the dealer had no problem taking care of the problems with out asking a question...
T
The wife and I mowed our 2.33 acres last Tuesday.
She was using our CC GT2554 and I was on the BX 23.
She was mowing a 54'' swath and I was cutting a 60'' path.
It was suprising how long it took to mow 2.33 acres even when cutting a 9.5 foot strip.
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
48" Skid Steer Pallet Fork Attachment, Asset# 66 (A59076)
48" Skid Steer...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
