Caulking/Sealing Concrete Expansion Joints
/ Caulking/Sealing Concrete Expansion Joints #21
Bird, many years ago in Dallas, when I was having the patio around the pool redone, they filled the cracks between the flagstones with a grouting compound and then pored sand over the top of it. They came back next day and swept the loose sand up. It gave the grouting material a nice finish. Much better than just the straight grout.
/ Caulking/Sealing Concrete Expansion Joints #22
I have concrete driveways that I guess are 18 years old. As I guess is common, they were built with wood (1 x 2?) in the expansion joints. That wood has rotted and much of it is missing. So dirt, leaves, grass clippings, etc. gets in the cracks. Yesterday I noticed a pedestrian sidewalk at an outlet mall that has some kind of gray, rubbery stuff in the joints. Can someone tell me what that stuff is and where to get it, or tell me something better to use?
Bird, My first guess would be polyurethane caulk. "Gray, rubbery joint sealer", sounds like Sikaflex 1A, color limestone, it's pretty much the industry standard around here.
http://www.sikacorp.com/tds-cpd-sikaflex1a-us.pdf
It comes in a caulking tube, it does take a little bit of a skill level to make it come out nice and even over a long joint, but if you have ever done any kind of caulking where you had to "tool" the joint, you'd be fine.
I can't compare it to the self leveling stuff cause I've never used it, but this caulk is a premium construction material, we use it in the most demanding applications like flashings, sills, lintels, vertical and horizontal expansion joints, capstones on parapets.
I just did a little reading (in the middle of this reply) on those Polyether self leveling materials and they sound pretty good also. might be just what you need.
What ever you choose, Good Luck, one tip when your doing a job like that is to mask the top edges of the joint with tape, gives you a nice straight line and keeps surrounding surfaces clean.
JB
The stuff I got at Home Depot is Sikaflex SL. Since it also says "Professional Self Levelling" it appears obvious as to what the "SL" stands for, but I have no idea what the difference is from the Sikaflex 1A. But this stuff is in a tube to be dispensed with a caulking gun, however, it says to dam both ends of your crevice, no trowling required, for horizontal cracks, not to be used on slopes, etc. so I expect it to be pretty thin when it comes out of the tube.
I can't say I've had a lot of experience with caulking, but I've had more than I wanted.:D
/ Caulking/Sealing Concrete Expansion Joints #24
Sounds like good stuff, it is a polyurethane, only designed for that one horizontal application.
http://www.sikaconstruction.com/tds-cpd-Sikaflex1CSL-us.pdf
Just make sure you have the bottom sealed off good with the backer rod or else the stuff will just "drain" out, it will find any void to fill in. The trick is gonna be to put enough in to fill it close to the top without spilling over and making a mess. The more level the joint is the easier it will be.
If you have trouble finding the backer rod at HD it's usually where the weather stripping is not where the caulks and sealants are sold, at least that's where it is in the HD here.
/ Caulking/Sealing Concrete Expansion Joints #25
Sikaflex 1A is usually what i use. I havent tried the Sl .
But some advise, check the expiry date on the tube (i think its on the bottom IIRC). Depending on your particular HD location they might not have enough turnover to keep fresh product on the shelf.
Interesting that you would mention that.:D I looked on the Home Depot and Lowes websites and neither one showed "backing rod". So at Home Depot, on the shelves with the motar mix and caulks for cement and asphalt, I was hunting the backing rod; couldn't find any. So I went to the contractor's counter and a nice gentleman there said it should be right there on that shelf. So he and I went together to look and couldn't find it. He said someone must have moved it or maybe they were out. So he went back to his computer and finally said it showed they had 18 packages of 20' rolls. He said they only stock the 3/4" size. So we went looking again and he finally saw a box way up at the top shelf that was labelled "Backer Rod". So then he had to go hunting a ladder. And as he was coming back down the aisle with a ladder, I turned around and just happened to notice packages of Backer Rod hanging on a bracket at eye level on the other side of that same aisle.:D
Now that would sound like some logical advice, so you've had me examining these tubes with a bright light and a magnifying glass and if there's an expiration date on them, I sure can't find it. There's a "Code" number and a "Lot Number" but no dates that I can find.
/ Caulking/Sealing Concrete Expansion Joints #27
You said you have pretty big joints, but I will tell you that stuff is a royal pain to work with if it's to big. It can be cut, also a pain, but be careful compressing it to much cause it will spring back up and push your material out or at least make a lumpy looking finished product.
Scooby074 mentioned shelf life, that is one of the negatives with the 1a anyway, I've thrown alot of tubes of caulk away being unable to gun it when it gets to hard. It has a painfully short shelf life, I've got a half case now left over from a job this season, customer paid for it but I know if I don't use it soon it will go to waste, will be no good next season.
JB.
/ Caulking/Sealing Concrete Expansion Joints #28
What is the life expectancy of this sealant v. putting in trex or PT?
/ Caulking/Sealing Concrete Expansion Joints #29
Bird--
Some of the advice you are getting here is good. Some is not. DO NOT replace the rotted joints with wood or trex (both will rot out again). Definately do not replace with mortar or concrete mix, as this will defeat the purpose of the expansion joint. The backer-rod from Home Depot a good option, though we use sand for a less expensive alternative (this will also help deal with the nails/wire weld mesh you are encountering in some of the joints). Sika is a really good product for this application, even for the wider points. Some local pool supplys may have aless expensive alternative such as deck-o seal. I would recommend that you pressurewash each joint to be caulked first, then sand, then caulk--about 1/2" deep. If you wish, you can "seed" the top of the caulk with sand to give it a mortar-like appearance, without impeding its flexibilty. Simply sprinkle the sand over the caulk once it is tacky, and leave until caulk has cured, then use blower to remove excess sand. We use this method every day with great success. Good Luck!
/ Caulking/Sealing Concrete Expansion Joints #30
Butyl Mastic.
It skins, however the interior remains soft and flexible, perfect for expansion joints in concrete.
Good for 3/4" joints too unlike silicone.
I got a lot of good information, advice, and help with this thread, and I finally got some weather to put it to use. Home Depot only had the backer rod in one size; 3/4" which still did not really fit snug in the crevices.
The first picture is where the 3' wide sidewalk adjoins the driveway. Yesterday afternoon, I put two strands of the backer rod in that crevice, then applied one 10.1 oz. tube of gray Sikaflex SL sealant. It looked good when I finished, but when I went back later, I found that the sealant had leaked down around the backer rod unevenly; not too bad, but not good either. So, this morning, when I did the rest of the job, I added some of the sealant and hope the fresh stuff adheres well to that which was applied 16-17 hours earlier.
The second and third pictures are of the 16' driveway at the garage door apron. Again, I first inserted two strands of the backer rod. Then I added 20-25 pounds of sand and worked it down over, but also around, the backer rod with a wide putty knife. And finally I applied almost all (not quite all) of two 29 oz. tubes of the same sealant. Not as pretty and neat as I'd expect from a professional, but I guess not too bad for an old amateur.
The pictures might have come out better if I'd taken them early, before the sun and shadows showed up.
The fourth picture is a sample of the (hairline?) or larger cracks in several places in the driveway. After wet weather, it seems that some moisture wicks up through those cracks. They're definitely too small to use the Sikaflex on them, but is there a sealant you'd recommend? And the dark, or black, part of the photo is the shadow from the tree behind me.
/ Caulking/Sealing Concrete Expansion Joints #32
Looks OK Bird, it will weather and get dirty so will blend in better.
Once you gun that stuff out, it's beyond your control, so I guess that self leveling stuff isn't any easier to use than the reg tool finished polyurethane, maybe in some regards tougher.
As far as those smaller cracks go, anything you do to them is gonna make them stand out like a sore thumb. They have probably been the same size for a long time and will not likely get any bigger.
If you had to fill them, you could use a clear silicone caulk with just a tiny tip cut, inject it in the crack and clean off the excess, but that stuff is glossy and would attract attention to the cracks, likely looking worse than just the cracks.
JB.
/ Caulking/Sealing Concrete Expansion Joints #33
Nice job on filling in the grooves, Bird. As John said, almost anything you do to the cracks is gonna stand out. I've seen many repairs using hot tar, but they look very ugly. It keeps the water out so it won't freeze and expand, but it wouldn't be my choice for a driveway. I think I'd be tempted to fill the cracks with fine sand-blasting sand and then squirt in a two-part epoxy from one of those dual mixer tubes. Epoxy adheres very well to concrete and even glass, so it might be just the cure. I think I'd experiment with a small area before doing the whole thing though.
/ Caulking/Sealing Concrete Expansion Joints #34
I have similar expansion strips in my driveway, I have a plastic U shaped extrusion that sits with the solid side up.
The strips are used for running low voltage wires for driveway lighting, so I don't want to fill them in.
Try a concrete supply company for these, not sure of what they are called, but might do the trick.
/ Caulking/Sealing Concrete Expansion Joints #35
I had a brain storm (more like the fog between my ears cleared for a second or two) for the wider cracks use pipe insulation as backer rod.
tom
That might be a good idea, Tom.
/ Caulking/Sealing Concrete Expansion Joints #37
Bird, try leaving the sealant just a little lower than grade. I think the instructions say this somewhere. As for "sinkers", I always go back within an hour of first application to refill these. The Sikaflex is still fluid enough that added material just blends right in. Sometimes I have to babysit a spot if it still sinks but eventually it stops.
Yep, you're right, Larry. The reason I didn't do that was that I used up one tube of the stuff to begin with; just the right amount, and didn't want to open another tube to use just a little bit.:D But of course, I should have.
Bobcat S740 (A57148)
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
