Caulk tube spouts
   / Caulk tube spouts
*You can fit a small plastic tube over the spout in the length you need.
*Thanks.
The places I need to culk are about 4 inches beyond the end of the spout.
This is not the first time I've run into this problem.
Sure would be nice it they would put longer spouts on the tubes of caulk.
What ever I use the extension would have to be stiff enough not to bend to easy and tight enough not to slip off.
   / Caulk tube spouts #4
I had the same problem. Went to the "Dollar Store" or someplace like that, and bought a package of novelty-type drinking straws. These things are about 3/8" diameter, plastic and about 10" long. They also have a ribbed flexible portion so they can be bent. The plastic was thick enough that they were stiff, not thin like most straws.
I think these were in with the Valentine's Day stuff. May have similar at WalMart. Then, duct taped the straw to the caulk tube spout.
   / Caulk tube spouts
I had the same problem. Went to the "Dollar Store" or someplace like that, and bought a package of novelty-type drinking straws. These things are about 3/8" diameter, plastic and about 10" long. They also have a ribbed flexible portion so they can be bent. I think these were in with the Valentine's Day stuff. May have similar at WalMart. *Then, duct taped the straw to the caulk tube spout.
* I thot about using a small hose clamp with what ever I use for a spout extension.
I also considered using one of those small cans of spray foam but the tube is to short on them too.
   / Caulk tube spouts #9
Sounds like the ticket.
Thanks.
Lb59 south of Canton Ohio.
You are very welcome.:)
Polo1665
Last temporary disorganized
settlement in the north eastern
territory
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A53843)
2018 INTERNATIONAL...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
1987 FRUEHAUF 150BBL ALUMINUM TANKER TRAILER (A53843)
1987 FRUEHAUF...
3 - RIDGID THREADERS (A53843)
3 - RIDGID...
