Caterpillar 289d fuel pump runs but won't crank
   / Caterpillar 289d fuel pump runs but won't crank #1
Alan13073
289D
Ran the skidsteer for 30 minutes and grabbed a log with the grapple bucket and then shut the machine down while I went to dump my trailer. Returned in 20 minutes and tried to start it and heard the duel pump running but the machine wouldn't turn over. Checked that door was properly closed and the safety arms were down all the way. Still won't crank over. Starter relay/solenoid or faulty ignition switch? Any other thing that might prevent the machine from turning over? 2013 Caterpillar 289D High Flow. Thanks any ideas would be appreciated.
   / Caterpillar 289d fuel pump runs but won't crank #2
Given the symptoms, it could be one of several issues. Here are some troubleshooting steps:
  1. Starter Relay/Solenoid: A common issue is a faulty starter relay or solenoid. If you hear the fuel pump running but the machine won't crank, the relay or solenoid might not be engaging properly. Test the relay and solenoid to ensure they are functioning.
  2. Ignition Switch: A faulty ignition switch can also prevent the machine from cranking. Check if there is power to the switch and that it’s functioning correctly.
  3. Battery and Connections: Ensure the battery is fully charged and the connections are clean and tight. A weak or bad battery can sometimes cause the symptoms you're describing.
  4. Neutral Safety Switch: The machine might not start if it’s not in the proper neutral position. Double-check that the machine is in neutral and that the neutral safety switch is working.
  5. Safety Interlock System: Since you mentioned checking the door and safety arms, ensure there are no issues with the safety interlock system. Sometimes these systems can have faults that prevent starting.
  6. Fuses and Wiring: Inspect fuses and wiring for any visible issues. A blown fuse or loose connection can prevent the machine from cranking.
  7. Starter Motor: If the starter motor itself is failing, it may not engage even if the solenoid and relay are working. Testing or replacing the starter motor might be necessary.
You can also go to the link below to view the 289d specs.
   / Caterpillar 289d fuel pump runs but won't crank #3
Will it crank if you jump the solenoid? What does the battery read in volts @ rest? What about under load test? Are you getting power to the start terminal on solenoid? All fuses checked? seat switch? other "safety lockouts"? Did you have a fan, light or radio left on that drained the battery? lots of possibilities.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2020 COLOMBO TM LOT IDENTIFIER 203 (A53084)
2020 COLOMBO TM...
UNUSED AGT ATK-B1000 2 POST CAR LIFT (A51248)
UNUSED AGT...
