Category 1 Narrow 3pt hitch
   / Category 1 Narrow 3pt hitch #1
Bently
Mt. Hall, Idaho USA
Does anybody have specs for the various Cat I 3pt hitches?
I have a friend who has tractor the and the lift arms on the 3pt will only spread to 24" max, so standard Cat I implements are too wide.
I've seen stuff listed for Cat I N (narrow), not sure what the specs are, though.
Thanks,
Ben
Thanks,
Ben
   / Category 1 Narrow 3pt hitch #3
I've heard the term "limited Cat 1" used with some of the sub-CUTs, but not "narrow". You might be describing a Cat "0". Perhaps THIS will help <i> narrow</i> it down.
//greg//
   / Category 1 Narrow 3pt hitch #4
//greg//
   / Category 1 Narrow 3pt hitch #5
Sounds like a Cat. 0 hitch.
   / Category 1 Narrow 3pt hitch #6
   / Category 1 Narrow 3pt hitch #7
it is best to weld and adapter to the equipment to use with the narrow arms. As long as the tractor is large enough to handel the equupment. Cat-0 stuff seems to break a lot.
   / Category 1 Narrow 3pt hitch #8
   / Category 1 Narrow 3pt hitch #9
In some cases the pins can be pointed towards each other to eliminate that problem.
   / Category 1 Narrow 3pt hitch #10
2803 (A50460)
2803 (A50460)
UNUSED AGT SDA-140T LOADER (A51243)
UNUSED AGT...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
UNUSED FUTURE MINI EXCAVATOR HYD 18" AUGER (A51244)
UNUSED FUTURE MINI...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
