Category 1 Narrow 3pt hitch
   / Category 1 Narrow 3pt hitch #11
The subcompacts use a Cat 0 spacing with Cat 1 pins so it can be confusing. I've found that Cat 1 attachments will fit, provided the pins are turned inwards.
   / Category 1 Narrow 3pt hitch #12
</font><font color="blue" class="small">( I've heard the term "limited Cat 1" used with some of the sub-CUTs, but not "narrow". You might be describing a Cat "0". Perhaps THIS will help <i> narrow</i> it down.
//greg// )</font>
Thanks, that is what I was looking for. I did a search myself but found only sites that wants to charge me for the ISO standards.
ISO does list Cat 1 narrow as a category separate from Cat 0.
Thanks,
//greg// )</font>
Thanks,
</font><font color="blue" class="small">( The subcompacts use a Cat 0 spacing with Cat 1 pins so it can be confusing. I've found that Cat 1 attachments will fit, provided the pins are turned inwards. )</font>
This did not work on a standard sized Cat 1 PH digger. The tips of the pins were exactly 24" apart on the inside, still too big.
Thanks,
Thanks,
   / Category 1 Narrow 3pt hitch #17
Ok, we need pictures!
If the tractor is new, make sure the 3ph arms aren't on backwards, that can throw the geometry off. The in-law's tractor came with the arms installed backwards from the NH dealership, the tractor was a TC-30.
If you can't provide pictures, at least tell us what make and model of tractor you are working with.
   / Category 1 Narrow 3pt hitch #18
   / Category 1 Narrow 3pt hitch #19
Pictures would be good.
Are there chains crossed between the two arms to prevent sway in the lift arms? Make sure these are adjusted to allow full spread. There should be a turnbuckle or some means of adjusting them to tighten/loosen.
   / Category 1 Narrow 3pt hitch #20
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
OTC 1591A 10-Ton Air Lift and Support Stand (A54816)
OTC 1591A 10-Ton...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
