Catastrophic failure with Hydraulics
   / Catastrophic failure with Hydraulics #11
If you put the range selector in neutral you can tow it.
   / Catastrophic failure with Hydraulics #12
Not sure I understand circumstances "you dont want to get into".
What possible circumstances would allow you to get another machine to the field and tow it, but not a filter and a bucket of fluid?
Perhaps he doesn't want to get dirty. :ROFLMAO:
   / Catastrophic failure with Hydraulics #13
And still have to get the bucket of fluid and filter after it’s towed out. If I was about to pull the engine I’d be towing it out but a filter replacement??
   / Catastrophic failure with Hydraulics #14
Blackberries, snakes, mud, poison ivy, mosquitoes, Bigfoot sightings ... Not sure I'd want to be under a machine taking off a skid plate in some 'circumstances'.
   / Catastrophic failure with Hydraulics #15
And would that be so hard to say other than "I don't want to get into it"
   / Catastrophic failure with Hydraulics #16
Maybe its somewhere its no supposed to be!
   / Catastrophic failure with Hydraulics #18
"I paid good money for a fancy skid plate that didn't protect the hydraulic filter. It does, however, prevent changing the filter with the skid plate in place".
   / Catastrophic failure with Hydraulics #20
A skid plate wouldn't have done much to prevent a sapling from coming up over my front axle, finding a gap below the radiator, and pushing the engine belt off as it threaded its way in.
I was flail mowing and hate to shut down when hot, but without the water pump running it would have run hotter. I shut down when the temp needle rose quickly. Just as I lifted the hood the AF res bottle overflowed. You bet I was scared. I was also lucky and no harm seems to have come from that one time I've had a tractor overheat.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVELER (A54757)
UNUSED WOLVERINE...
1990 CASE 90XT SKID STEER (A52705)
1990 CASE 90XT...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
BUNDLE OF 25" - 49", 2" X 2" TUBING (A54756)
BUNDLE OF 25" -...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
