Catastrophic failure with Hydraulics
   / Catastrophic failure with Hydraulics #11
If you put the range selector in neutral you can tow it.
   / Catastrophic failure with Hydraulics #12
Not sure I understand circumstances "you dont want to get into".
What possible circumstances would allow you to get another machine to the field and tow it, but not a filter and a bucket of fluid?
Perhaps he doesn't want to get dirty. :ROFLMAO:
   / Catastrophic failure with Hydraulics #13
And still have to get the bucket of fluid and filter after it’s towed out. If I was about to pull the engine I’d be towing it out but a filter replacement??
   / Catastrophic failure with Hydraulics #14
Blackberries, snakes, mud, poison ivy, mosquitoes, Bigfoot sightings ... Not sure I'd want to be under a machine taking off a skid plate in some 'circumstances'.
   / Catastrophic failure with Hydraulics #15
And would that be so hard to say other than "I don't want to get into it"
   / Catastrophic failure with Hydraulics #16
Maybe its somewhere its no supposed to be!
   / Catastrophic failure with Hydraulics #18
"I paid good money for a fancy skid plate that didn't protect the hydraulic filter. It does, however, prevent changing the filter with the skid plate in place".
   / Catastrophic failure with Hydraulics #20
A skid plate wouldn't have done much to prevent a sapling from coming up over my front axle, finding a gap below the radiator, and pushing the engine belt off as it threaded its way in.
I was flail mowing and hate to shut down when hot, but without the water pump running it would have run hotter. I shut down when the temp needle rose quickly. Just as I lifted the hood the AF res bottle overflowed. You bet I was scared. I was also lucky and no harm seems to have come from that one time I've had a tractor overheat.
CLUBCAR GAS GOLF CART (A54756)
CLUBCAR GAS GOLF...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
KEWANCE 200 9' GRADER BLADE (A54756)
KEWANCE 200 9'...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
