deserteagle71
Elite Member
- Joined
- Dec 30, 2017
- Messages
- 2,940
- Location
- northern Nevada
- Tractor
- John Deere 2020 diesel, Kubota M7060HDC12
Don't you have to wear an eye patch for a couple days after surgery? ISTR that being the case when my wife had hers done a couple years ago. Not sure I'd want to be blindfolded for a couple days.
How bad was your astigmatism? I have it pretty bad in one eye (to the point of just barely being correctable with glasses), and I was told that cataract surgery would require a special procedure that was not typically covered by insurance. Fortunately, I have minimal cataracts so not really an issue right now.
I didn't have to wear a patch. I had to wear a clear plastic cup over the eye for a couple days...but that is just so you don't inadvertently touch the eye while it is healing from the surgery. As to the cataract surgery - I believe it is all the same. No special procedure. BUT...when they do the surgery you are given the option of having 3 different types of lenses implanted to replace your natural ones. A generic lens without any vision correction - and this is the only type of lens insurance will pay for. Then a lens that will correct your astigmatism and give you either perfect distance vision or perfect close-up vision. Your choice. That one you have to pay for (the lens itself, NOT the surgery). This is the option I chose and it cost me ~ $1500 per eye if memory serves me correctly. The third option I was offered was a lens that would give great vision both near and far but would cause flare with bright lights, especially at night. Since one of my main problems was flare this last option I didn't want.
I think this choice business is stupid. So the insurance will not pay to have lens inserted at the time of the surgery to give you perfect vision...but then they will have to pay for your glasses, so you can get sharp vision, for years???
By the way, the procedure to get correct lenses (that correct for astigmatism and nearsightedness and farsightedness) is amazing. If you choose that option you don't have to go through a whole bunch of tests to get the correct lenses. They sit you in front of a machine and in a few seconds it seems like you are done. The machine does a scan that provides the doctor with the measurements needed to grind the lens precisely to that eye.
