Catagory 1-2 hydraulic top link
   / Catagory 1-2 hydraulic top link #1
longlane
Vineland, NJ
Ford 5000
Im looking for a hydraulic top link, Category 2 on the tractor end and category 1 on the implement end.
I have found manual top links in this configuration, but not hydraulic.
Any guidance would be appreciated.
thanks
   / Catagory 1-2 hydraulic top link #2
thanks
If you have the capabilities to weld it is really easy to change the rod end of a cylinder...otherwise is simple for a welding shop...
Another option is just use a fitted sleeve on a cat 2 HTL...
   / Catagory 1-2 hydraulic top link #3
   / Catagory 1-2 hydraulic top link #4
I also have his products and like them.
   / Catagory 1-2 hydraulic top link #5
   / Catagory 1-2 hydraulic top link #6
Pretty sure "not" was a mistake!?!? Funny that I do it all the time the other direction, I would leave out the word "not" from sentences. :confused3:
Bushing at Agrisupply:
Lift Arm Bushing Cat 1 To Cat 2 | Agri Supply 106048
Thanks for catching that..... :thumbsup:
YES.... It should have read:
"I CAN NOT RECOMMEND BRIAN OVER AT FIT-RITE HYDRAULICS HIGHLY ENOUGH".... It's what happens when my brain works faster than my fat fingers.... :confused2:
   / Catagory 1-2 hydraulic top link #7
For those that skim through posts, they might see "I can NOT recommend" and think OK, NOT this guy, and move on. I have a top link by Fit-Rite-Hydraulics. Good product, even came JD green.
UNUSED RAYTREE RMDM72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
New Kivel Skidloader Double Bale Spear (A50775)
New Kivel...
CATERPILLAR 307E2 EXCAVATOR (A52705)
CATERPILLAR 307E2...
