Cat1 3ph question...
   / Cat1 3ph question... #1
smokedtires
Bronze Member
Lysander NY
I stopped by a local Tractor Supply Co to look at their box blades. They recommended a King Kutter XB box blade that fits category 1 tractors with category 0 spacing. Now I'm not sure if this would be correct or not for my JD 4100, any suggestions will really help. How do I know if my CUT has a 1 or 0 spacing or does it not really matter?
Thanks.
   / Cat1 3ph question... #2
You will have no problems with the boxblade for the 4100, it's bigger than mine and I could hook up to that one.
   / Cat1 3ph question... #3
I also have a 4100. I have a Kubota 48" box scraper I use with it. My 4100 has the R4 industrial tires, which can only be placed in the narrow position and I have a problem with the tires scraping the 3-pt arms with the box scraper attached. I don't have this problem with my King cutter rear blade though. The pin spacing on the Kubota is 27" I think.
   / Cat1 3ph question... #4
My 4010 is Cat 1; your 4100 has to be. Cat 1 is 26" wide at the lift arms.
I've a Frontier back blade on my 4010. Bought it from the dealer for $250. It also has pins on the inside for Cat 0 machines.
Ralph
Great, it looks like the XB should work then. I just wasn't sure about the Cat 0 spacing. Thanks /forums/images/graemlins/smile.gif
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
New Holland B95 Backhoe (A50490)
New Holland B95...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
